FAST intake and boost.
how much boost can a FAST intake take? would that be a good choice orr is there something better? i was looking at wilson intakes but theyre a little up there. thanks..
An ls2 block isn't going to hold alot from twin 88's, and it's going to take some serious cubes to make effective use of twin 88's, which if used correctly, would certainly assassinate the rest of the driveline.
I read somewhere that the new 102mm FASTs are good to 67psi. I have one, but no boost.
Edit: Googled, LSXR boost. Came up with this....
"The LSXR™ is constructed from a proprietary advanced polymer material that has been burst tested to withstand 67 psi of boost."
http://www.cpgnation.com/forum/fast-...-ls7-2504.html
yea i know. its going to be an lsx block..all the internals will be changed. going to be done right. so its going to take a little longer. and im not going to put it in a class or anything. just out to have fun.
Internet Mechanic
Ok, First off, this post would be better suited fpr the FI (Forced Induction) Section as this is a external part, the situation you maybe putting it in would require more "expert" advice.
When I was researching putting a D-1 ProCharger on my car which had a 90/90 Fast Set up. I saw people having intake failures north of 20 PSI. Since my car with a stock motor was not going to see that, I did not see the issue.
But beyond what I had remembered from my research. I do encourage you to search within that section first, and if a post does not match your need. Then make a new one.
20# on a FAST?!?! Not happening, well maybe for a few runs?
You are better off doing a carb intake, elbow, and TB at that boost level. Hell if you have the money do a sheet metal intake!
