bad fuel mileage
bad fuel mileage
I have a 99 camaro m6 with cold air, 4.11 gear 160 thermostats ,no change in mpg when changing to 4.11gears ,changed fuel filter still the same & cleaned maf & also seafoamed it still the same ,do you think it could be the thermostats ,the car run good ,but only gets about 9-10 mpg
4.11 gears should hurt your MPG, not help. Thermostat shouldn't make any difference positive or negative. Only mod it seems you have that should help is the after market filter/induction.
Generally MPG is about how you drive, not the car. Any type of spirited driving will kill your average.
How did you clean the MAF? Theres a chance you screwed up some of the wire sensors within that are screwing with you a/f ratio. Or it could just be a combination of the gears with needed a tune up (filters/plugs/wires/etc) B/c as stoleit said going with a higher ratio gear will hurt your MPG's if your driving habbits remain the same (although usually after people mod cars they tend to push it harder, which is why we mod them, to make them faster). Only way the gears will hurt the MPG's is if you lower the ratio
^ Another thing to consider is you dont know what kinda driving he is doing getting 9-10 MPG. My old cam F-body M6 still got great highway MPG but it hurt my city driving, especially b/c I beat on it more. Although there is a good chance the MAF or o2s can be causing the problem, I wouldnt rule the gears out for some effect yet until we know all the info
