Book calls for 91 oct
I hate Maine. All we have here is 91. If we sold 93, she would be drinking it. My 6 banger gets 91 even though the book says 87. Am I wasting money? Maybe, peace of mind is priceless though.
LS1Tech Administrator
Received 1,726 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Best power and MPG will be achieved when the lowest octane that still 100% prevents detonation is used. You want combustion to happen as easily as possibile without detonation; and higher than necessary octane will cause slower/later than optimal combustion. Engines with high compression/aggressive ignition timing, and/or forced induction will want higher octane. A stock, NA 3800 Series II V6 will do better in all categories with 87 octane.
Or a supercharger! My comp g gtp calls for 91+.
Back to what RPM WS6 said,
haha i understand your analogy, but there are also MANY MANY more benefits to synthetic than just oil change intervals. i change my synthetic every 3k miles on my turbo car.
so your analogy should be, "Putting 91+ in the 3.8 (n/a) is just about as pointless as the people putting a "tornado" air intake on their car. just wastes money and time....
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Actually it's more than just wasting money, by running 91 in a motor that calls for 87 you're also reducing MPG and engine performance. There should be no peace of mind in that.
Again, Agreed. Will I stop. Nope. Would I recommend this to anyone else. Nope.
I used to run 87 in my LS1, since premium is only recommended. I never had any problems, and it ran just fine.
More recently, I've been putting in at least 89. I usually put in 93, put sometimes I mix in some 89 to make it closer to 91.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Couldn't agree with you more. I've put 60k miles on this car now and for the first 1 or 2 thousand miles I ran 87. For some reason it ran like **** leaving me to believe it was dynotuned by the previous owner. Could never confirm it though. Switched up to 91 and the car ran smoother, ticked less and started getting better mpgs. Just my experience with this car. Dynod the car a few years ago and put the numbers down I'm showing in my sig which was more than I was expecting for a bolt-on 3.8.
I'd probably toss a scanner on it and see where the timing is at compared to a stock L36, just for the hell of it.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I can't understand why people buy these cars and whine about running 91+. If you drive 10,000 miles a year and average 20mpg, the difference in 87@2.80/gal and 93@3.00/gal is only a savings of $100 a year. If you can't come up with $0.27/day you should've bought a scooter and not an F-body.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Douchebag On The Tree
I always ran 91+ in my L67 and would never think to run anything lower without a scantool.
Boost = Hot Spots = Detonation
