What mpg would a 4.8 get in an F Body?
I'm putting together the parts for a 2WD CJ5 hot rod thingy. I am planning on using a 2002 Tahoe 4.8. I am hoping that I might get as good of mileage with the 4.8 as I would if I use an LS1 with the same tranny. What do you think? The 4.8 runs on regular so I assume it has lower compression but since it is smaller maybe that will make up for it? The epa mpg rating for a C1500 is only 19 highway and an LS1 camaro rating is like 25, but I've heard they can get close to 30. I wonder if an F body with a 4.8 would do that? (Not that anybody would)
Fuel economy is not apples and oranges. It is based off the engine, gearing, weight and wind drag.
Would you expect to get 100 miles to the gallon if you used a moped drive train?
That's common with the 4.3 V-6. I think the extra torque of the 4.8 helps things out a little in that department, although I still would prefer a 5.3 or 6.0.
I doubt a 4.8L f-body would get as good gas mileage as a stock LS1 car. There's the line between not having enough power and getting lower gas mileage because the engine is constantly struggling to move the vehicle (I had a 18' moving truck with a tandem-axle trailer hauling my T/A when I moved that had the 4.8L...talk about an underpowered, dangerous brick) and an overpowered engine that gets poor gas mileage. The LS1 cars seem to be right on the line of having an engine that makes enough power to move the car with plenty of headroom, but aren't so hot from the factory that gas mileage suffers from making power.
The lighter weight of the LS1 over the 4.8 doesn't hurt either. I am not a fan of the 4.8, but if they insist on keeping the 4.8 on the engine list, I firmly believe that it needs to be the base engine. The 4.3 V-6 is long overdue for burial. Put an LQ4 in that "thingy" and go play!
1 Post
My Truck being as small as it is fine w/a 4.8 and i think the new ones have over 300hp now which is not bad.W/155,000 miles on her and she still gets great gas mileage and moves pretty good when u need her too.
In all reality If you do the swap I would not expect great MPG's over a stock LS1, because LS1's in a F-body and the 3800 series V6 in a F-body are pretty close as far as MPG's go, so I would expect the same from a 4.8
Douchebag On The Tree
THIS!!! you cant compare the MPG's of a LS1 F-body to the 4.8L in a truck. Gearing, transmission, weight, and drag, in addition to other variables are all going to have a big effect on fuel millage. The overall setup will probable have a bigger effect on MPG's then the engine swap.
If you really wanna maximize mpgs then you need to remove as much weight as possible and switch to the 2.7X gears A4's can have.
