View Poll Results: will i break 400 wheel horse power?
no around 370
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
1
11.11%
yes
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
8
88.89%
no but close
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
0
0%
Voters: 9. You may not vote on this poll
my new setup for now on my hawk.. :)
hey guys, just wanted to tell some people my set up on my firehawk..
ok so
saved some big money and decided to spend it on myself for once..
02 firehawk
390 motive gear
d & d performance chevy/viper t56 transmission
ls6 clutch and aluminum flywheel.
pro 5.0 shifter
lsx fast 102 mm throttle body
slp mass air flow..
LS1 Comp Cams LSR Cathedral Port Cam (243/251 114LSA) 5.7L-6.2L
(Int. 243 Ext. 251 Lift Int. .624 Exh. .624 LSA 114°)
Patriot "Gold" Dual Valve Spring Kit
hooker long tubes 1 3/4 no cats
borla no cats connected to y pipe
slp diablo sport tuner.
nitto 555r back tire.
gunna save and get 102mm fast intake manifold.. but for now what should i expect for dyno results? any opimons?
or et predictions
was running early 13's before most mods..
also my fast throttle body will bolt up to my stock manifold right?
thanks and let me kno what u think of my setup
frank
ok so
02 firehawk
390 motive gear
pro 5.0 shifter
slp mass air flow..
or et predictions
frank
Last edited by 02_Firehawk; 09-15-2010 at 06:52 PM. Reason: forgot to add something
Wouldn't waste the money on the SLP MAF, tuner, or LS6 clutch. Get a good SD tune and ditch the MAF after the cam goes in, and pick up an LS7 clutch instead. The 102mm TB won't mount up to a LS1/LS6 intake - it uses a square 4-bolt design, rather than the 3-bolt design the LS1/LS6 intakes use.
Definitely going to need some suspension work, too, and hopefully the 3.90s are going in a 9", not the 10-bolt.
hp predictions?
I would imagine 430rwhp with a good tune, could be more. I suck at hp guessing.
Suspension, I'd say LCAs, LCA relocs, and a torque arm, and a torque arm relocation crossmember would be a good idea, too. That's with a 9"...for a 10-bolt, you'll want as little traction as possible.
MAF on a stock setup is fine...why wouldn't you want to go with an SD tune, though, with what you're planning on doing? A handheld isn't going to do **** for that setup - some dyno time with a good speed shop tuner is a must.
Also check out Finish Line Performance. They are near chicago and have tons of experience with LS cars.
I would just stick with your stock maf, throttle body and intake for now. The 102 is just too big for ya, I would just port your stock TB, get an underdrive pulley. Put the leftover $$$ into to a good dyno/street tune, you should be able to break the 400hp mark.
That said, I think there's more benefit to buying an LS6 and spending the rest on things like suspension and picking up a FAST when a cam goes in, than sticking a 102 on a stock-internals car.
102's been shown not to lose anything to the LS6 on bolt-on cars. Granted, it's not nearly as beneficial to those cars as it is H/C cars, but it makes more sense to buy one $1200 intake/TB that'll provide plenty of headroom, rather than buying a $350 LS6, then a $800 FAST 90 combo, then a $1200 102 combo, even given decent resale prices on the LS6 and FAST 90 stuff.
Element, you should look into a Tick MC as well for your new clutch/tranny, man those things are worth every penny. They just went on sale too for $299-
1 Post
If you are looking for specific numbers base your car off of someone elses that make close to 400. Like most people said some of the parts you have listed are not worth the money
https://ls1tech.com/forums/dynamomet...no-thread.html
With being in chi town I figured there would be a few good places... Modern-muscle does good work and they are up there.. If I had an lsx motor I would deff take my car there.. Damn u ltx
lol
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
If you haven't bought all this stuff yet, sit down and rethink what you are doing. You can spend your money on a different setup and probably be happier in the end. Ditch the maf, tuner, and ls6 clutch. Put the 102 tb in a box and save it until you buy a 102 intake and heads. That cam is big! I would say bigger gears, better clutch, and a dyno tune.
