Hot Wheels 4th Gen Firebird???
You know what, back in the 90's I'd pick up a Hot Wheel or Matchbox every time I went to the grocery store, and I don't think I ever came across an F-bird. Now, I do remember Hot Wheels LT1 cars with racing emblems all over them, but I don't recall seeing any plain 'ol street car themes; I sure as hell don't recall any LS1 bodies. Personally, I have a black, '97 WS6 with its t-tops off from Matchbox...
![](http://i237.photobucket.com/albums/ff279/pdennis93/generic%20photos/100_0110.jpg)
Well that's good then that you are getting the light weight fly because that is what my brother ordered from tick. He does a lot of roll racing and could care less about having the inertia of a heavy flywheel to get him out of the hole. We are going to do a roll race before the light weight fly install and after to see how much of a difference there is in accelleration. I'm guessing about a car length from 25mph-100mph.
I will have to take a pic of my collection as well, I have a bunch of Camaro's and a few Trans Am's. I do want to add a LS1 T/A to my collection and the amazing spider man one may have to do!
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
http://cgi.ebay.com/Greenlight-Motor...item27b6c93585
http://cgi.ebay.com/3-CAR-FIREBIRD-L...item255f313670
http://cgi.ebay.com/GREENLIGHT-1999-...item3a6100640f
http://cgi.ebay.com/Matchbox-Premier...item2a0c2c8730
Want to spend a pretty penny hahahaha
http://cgi.ebay.com/2002-TRANS-AM-CO...item2304363d4d
http://cgi.ebay.com/2002-TRANS-AM-CO...item2557a24eb1
http://cgi.ebay.com/GREENLIGHT-1-12-...item35aca71892
http://cgi.ebay.com/1999-PONTIAC-FIR...item255c1b5c69
http://cgi.ebay.com/GREENLIGHT-1999-...item3a61005ffc
http://cgi.ebay.com/2002-PONTIAC-FIR...item2308435cc9
there are a ton more, just look up Trans Am Toy on ebay
Absolutely! I will be putting the LS7 clutch in sometime next year myself actually...and although I have a general idea of how it goes...seeing it done makes me feel 100 times more confident. I'm probably going to go with a aluminum flywheel though...and just quit downshifting all the time when driving on the road. Should get some good video with two of you doing the work too.
Thanks for your info
Wow I have the B&M one and I have been scavaging the old antique stores with my wife for old Firebirds. I also look for the newer one everywhere else. But to no avail. I will have to say that the one collection is awsome.
ive got over 100 johny lightning fdodys unopened 1st gen all the way up to now even lt1s and ls1 and ceta. I even have a 97ss that was in camaro mag. Also have several 4th gen camaro and trans am models in box with original rapping still sealed.
Hey this doesn't really pertain to this thread. But I am still a beginner mechanic and I've been wondering what the difference is between flywheels. Are you saying with an aluminum one you can't down shift? If so, can you still down shift with a steel flywheel? Sorry again for getting off topic, I'm just trying to learn as much as I can since I just picked up a '96.
I'm not one to go screaming "Search"....so I'll give you my quick $.02 on it.
The whole deal with getting an aluminum flywheel instead of a steel one is reducing some of the rotating mass. I know my numbers are off here...but go with me. A steel flywheel weighs some 18 lbs, an aluminum flywheel weighs som 8 lbs. The engine has to rotate the flywheel...and the heavier the flywheel, the more strain on the engine to get that momentum to rotate the flywheel. The lighter the flywheel...the easier it is for the engine to rev up AND down. If there was no downside to a lightweight flywheel...everyone would have one...but when driving with an aluminum flywheel...the clutch can grab it a lot easier since there's less "weight" rotating that it has to grab. if you're not rev matching when you down shift...the car can buck like you don't know how to use a clutch. An aluminum flywheel is for those people who know what it does and how it can benefit them while they're willing to cope with the disadvantages. Personally...I rev match every downshift already when racing, so I can deal with that, and on the street..I won't be downshifting all the time...car's too loud and ticks people off beside me. The benefit for me is when I autox coming out of a tight turn at lower speeds when I'm down in the rpm's. It doesn't take as much power to rotate that aluminum "weight" as it does a steel "weight". The same principle applies to steel vs. aluminum/carbon driveshafts and the benefits are similar principles to an UD pulley as far as quicker revs go. If you're only using the car for the street...don't worry about ever getting an aluminum one unless you're just hardcore set on it. By all means, do what you want with your car...but I see that money being better spent elsewhere. If you're into autox/road racing....it may be a potential upgrade for you in the future. If you're into drag racing....it just depends on your flavor of it. Do you want that heavy rotating mass to help get you from a dig....or do you want less rotating mass to help you get into your power range faster. That'll all depend on your style of drag racing....I've been down the 1/4 mile twice in my car...so I'm not most knowledgable when it comes to that. But hopefully my explanation will help you out a little.
#32
I want to find a Hot Wheels car anyway. But you can build one like I did:
https://ls1tech.com/forums/racers-lo...d-up-pics.html
![](https://photos-h.ak.fbcdn.net/hphotos-ak-snc3/hs141.snc3/16865_1300982533720_1505130034_30794264_7977443_n.jpg)
#35
ProStock LT1 bird by Hot Wheels.
http://www.hotwheels.com/cars/pro-stock-firebird-0
And a Johnny Lightning 01 Trans Am
http://cgi.ebay.com/Johnny-Lightning...item51929f1207
Here is a Johnny Lightning Black WS6 with TT2's lol
http://cgi.ebay.com/JOHNNY-LIGHTNING...item56416a7e5e
#37
Hollo. How did you get dual exhaust. I got one of those 2n1's, but it only gives me single outlet exhaust? the only trans am ws6 kit I could find was a 98, which makes the single outlet correct, but I want it to look like my car which has dual.
Anyone have a Camaro model? If so, does it come with dual exhaust? I imagine I could use the exhaust off that kit and make it work.
#39
Location: The dirty taint of the country. ...Los Angeles
there are a ton more, just look up Trans Am Toy on ebay![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
#40
