I am looking into an LS1 FBody. Do they run hot inside like the Viper
I know that when I read reviews of the Viper, one of the biggest complaints is that the engine is so hot and that heat is then transfered into the cabin. My dad had one and I can assure, this is a complaint for good reason. Is this an issue at all with the LS1 FBody? What about larger displacement versions like strokers, any difference?
To go a little off topic, are there any issues similar to that that I should prepare for? The specific car I am looking at is a 1998 Trans Am with a 383 LS1
Thanks,
Lawrence
Thanks,
Lawrence
No heat from the engine is felt whatsoever. These cars have a nice insulated fire wall that keeps all that heat out of the cabin. I've never heard about the Viper issue before, is that common on all models?
Leaky and noisy rear ends, piston slap, window motors, headlight motors (only a problem for Firebirds of course), weak rotors that warp, crap speakers that blow easily, factory shocks are awful, cats that clog prematurely, non-functional trunk releases, cracking interior panels, etc.
That being said, I LOVE this car and hope I never have to sell it. These problems are common but chances are you will only have to deal with a couple of these issues.
I've had a few of these issues, but they're nothing major... the car has always started and driven fine, very reliable car in that sense.
Honestly not many, especially if the car is kept near stock.
Window motors are known to wear out/die easy, but are easy to replace and cheap ($50 give or take from autozone). Headlight motors are known for some issues as well, either dieing or eating through the gear (another easy and cheap replacement by buying a brass gear).
The stock 10 bolt rear ends can break if beaten on enough as well.
Other minor things are the factor rotors are known to warp easy (replace with something like brembo blanks) and the factory shocks suck, leaving you with a floaty disconnected ride while also being jarring and jittery and shitty handling, easy fix with some good shocks (like bilstiens or konis).
Its more so going to depend on the condition of the car and how the previous owner treated it, and what mods he has done.
Check out the FAQ too:
https://ls1tech.com/forums/new-ls1-o...questions.html
I think the issue with the Viper is mainly the routing of the exhaust (they are incorporated into the side kick pannels/skirts whatever you want to call them) and the heat radiates into the interior.
I do feel some hot air at times in my SS, it transfers through the shifter boot area. Not nothing like the older Vipers though.
I never notice any heat transfer from my motor to the interior and I have a 98. The A/C will freeze you out during a Texas or Arkansas summer.
The squeaks and rattles interior wise on mine aren't that bad. Especially compared to my old 91 GTA I used to have. It seems like everything with age and mileage rattles. Had a 97 Grand Cherokee and I swear it rattled more than my car does. Everything is just plastic nowadays.
bfft this dude said it all! other than that
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
