Cleaning Aluminum Engine Components
Does anyone have a good way to make the aluminum engine components look new again? My water pumper and engine brackets are all brown and dingy looking. I would like to make them look new again without painting them.
when it comes to aluminum parts that have not been clearcoated, i use 2500 grit sandpaper and watersand the part then i use neverdull to bring it to a brilliant shine, let me know if you need more details, i have handpolished quite a few parts from raw to mirror
Take a scrub brush with degreaser or soap and get all the crud off. Then wash and dry them with normal water and a towel. Then hit them with some Duplicolor 500 degree thats a natural aluminum color. Wont take long and it will all look brand new. Sanding water pumps is a little **** to me
For some motivation, look here:
https://ls1tech.com/forums/racers-lo...ew-engine.html
https://ls1tech.com/forums/multimedi...lots-pics.html
The aluminum I am referring to is the water pump & brackets. But, it would apply to my heads and 4 barrel intake as well. So, the polishing deals would not work out for that application unless I was willing to sand down and polish all of those components.
Sandblasting creates a dull gray finish that does not look like natural cast.
I tried the aluminum cleaner from Napa. It works very good, but if you leave it on too long the surface turns dull gray like sand blasting.
I would like to try the Zep aluminum soap. My friend used to rebuild transmissions. He had a hot wash cabinet that used that Zep soap. When the cabinet was clean, it worked excellent. But, he is in a different business now.
The best results I have had so far is to clean it with the Napa aluminum cleaner, then restore the shine with a high speed wire wheel, then hit is again with the aluminum cleaner for about 3 to 5 seconds. This gets the sheen just about right. However, I can't imagine being able to maintain it that way once it is assembled and in the car.
While I was going for the natural look, I am seriously thinking about just finding a nice silver color code and painting the whole thing in PPG. I did this in Silver and Red with my Grand National and it looked great and cleaned up in minutes with some soap and water.
Using the NAPA aluminum cleaner with some high temp clear should give you good results that will last a long time.
http://www.amazon.com/VHT-SP115-Flam...=pd_sbs_auto_3
