switch for brake lights on/off
Just wire a toggle switch into either the power or ground wire for your brake light switch. This would kill the brake lights. If you want to kill all the rear lights it will get more involved but basically the same idea.
hmmm? any idea which wire? Im not good with schematics.
I'll run a toggle switch in between the ground wire and see if it works and post up.
Would the ground wire be located in the rear? by the tail lights?
