General LSX Automobile Discussion Non-technical LSX related topics.
Extending keyless entry?
Old Apr 8, 2011 | 11:30 AM
Clayton Andrew's Avatar
Default Extending keyless entry?
Anyone know the easiest way to extend the range for my keyless entry on my 2000 T.A. ?
Old Apr 8, 2011 | 12:06 PM
1Ls1's Avatar
is that even possible?
Old Apr 8, 2011 | 12:13 PM
Anything is possible
Old Apr 8, 2011 | 12:14 PM
Swaie's Avatar
doubt it
Old Apr 8, 2011 | 12:28 PM
Bramlok's Avatar
Hold the keyless remote so that it touches underneath the bottom of your chin. I thought it sounded stupid also until a buddy of mine showed me. It seriously does increase the range a little. Try it normally and then do it under your chin to test it out for yourself.
Old Apr 8, 2011 | 12:46 PM
t/a98's Avatar
Idk but my factory alarm has like twice the range of my remote. I can't lock or unlock from my bedroom but I sure can hit the alarm through the wall and everything and it still honks...
Old Apr 8, 2011 | 01:40 PM
I've seen this disproven. The height it what changes it, the chin is merely coincidence.
Originally Posted by Swaie
doubt it
It's based off of RF, to say you doubt its possibility is just silly haha
Old Apr 8, 2011 | 02:06 PM
FST SS's Avatar
bigger battery?
Old Apr 8, 2011 | 02:35 PM
gringo dfw's Avatar
When you hold a remote to your neck it uses your body as a antenna. Go to any valet service and watch how they can set off a car from double the distance when held to the neck.
if that doesnt work, your battery is low or the receiver antenna is not placed accordingly.
Old Apr 8, 2011 | 02:41 PM
oddwraith's Avatar
^^^I've heard this too and apparently from folks I know it does work. One more reason to get the bird out of storage I guess I want to try now lol.
Old Apr 8, 2011 | 02:43 PM
mike171562's Avatar
where is the receiver antenna located?
Old Apr 8, 2011 | 04:34 PM
^wish i knew :/ I have heard its somewhere under the glovebox... but idk for sure.
^If that were true, you simply holding it would work as an antenna as well...
Originally Posted by FST SS
bigger battery?
^its a set size battery slot...
Old Apr 8, 2011 | 04:45 PM
Bramlok's Avatar
Height has nothing to do with it.
Stand at just a distance to where it won't work. Hold it over your head as high as you can and it still won't work. Hold it to your chin at the same distance and it works.
Old Apr 8, 2011 | 05:00 PM
i am literally disproving that as we speak haha.
Old Apr 8, 2011 | 05:05 PM
riceburnerZ28's Avatar
Off topic a bit but what is the range of the factory transmitter? I've noticed mine doesn't unlock the doors until I'm about 5-10 yards away from the car.
Old Apr 8, 2011 | 05:07 PM
Same. I hate it.
Old Apr 8, 2011 | 08:54 PM
Empatho's Avatar
Mine is getting worst, I have to be like 5ft away
Old Apr 8, 2011 | 09:36 PM
Chrismikeb's Avatar
why do u want to unlock ur doors when ur 100ft away?! gives ppl a chance to hop in ur car lol, I never even unlock the door till im 5ft away, whats wrong with that?
Old Apr 8, 2011 | 10:32 PM
maybe 20-30 feet. helps in parking lots if i forgot exact row i parked in, or if i start walkin away and want to lock my car and by time i realize it, im too far. stuff like that...
Old Apr 9, 2011 | 07:30 PM
Lotus289's Avatar
There IS a way to do it. My friend did it to his '94 Firebird. It extended the range to a few hundred feet. We were about 6 houses down a standard neighborhood and it still worked. I'm looking for what it was he bought right now. I think it's made by Audiovox as part of their alarm systems. You solder an antenna extender on to two points on the BCM and you're done. I'll see what I can find; but it IS possible and I HAVE seen it done in person. Best part: the wire you use was only $20 or so.
