General LSX Automobile Discussion Non-technical LSX related topics.
o2 sensor question
Old Apr 13, 2011 | 11:03 PM
SilverBulletZ's Avatar
Default o2 sensor question
hello i have a 98 camaro with the ls1 and i recently bought the pacesetter lts with catless ypipe.... i only hooked up 2 o2 sensors into the headers and never hooked up the other 2 bc there wasnt any spots for them in the ypipe... will this effect the way my car runs?
Old Apr 13, 2011 | 11:18 PM
duvalsoldier904's Avatar
it shouldnt but when you go get your car tuned for the headers they should tune out the other o2 sensors
Old Apr 14, 2011 | 08:33 AM
Ok thank you
Old Apr 14, 2011 | 09:02 AM
6speedt/a's Avatar
You should have posted both of you issues in the same post because its more than likely related. get a mail order tune from Frost and that should fix all your issues. and was it cutting out like that before the header install
Old Apr 14, 2011 | 10:07 AM
it started after the header install. had it tuned on a mustang dyno... the guy said he didnt understand why it was cutting out. so you think the missing o2s is telling the computer the wrong info?
Old Apr 14, 2011 | 10:11 AM
and who or what is frost?
Old Apr 14, 2011 | 10:28 AM
6speedt/a's Avatar
start checking for melted wires than. your said nothing about having a tune and frost is one of the best tuners around. did you tune it up when you were doing the header install? did you take the spark plugs out during install?
Old Apr 14, 2011 | 10:38 AM
yes i took out the spark plugs but didnt put new ones in... ill look over the motor for melted wires...and can i get a link for frost?
Old Apr 14, 2011 | 01:10 PM
6speedt/a's Avatar
http://www.tunedbyfrost.com/
he is a sponser on here as well
Old Apr 15, 2011 | 04:54 AM
SOMbitch's Avatar
The rear o2's do not affect how the car will run and only tell the PCM if your cats are not functioning and will trigger the ses light unless tuned out.
I saw your other thread and if this car is stock internal wise why are you trying to turn 6500. Did this dyno operator set your rev limiter and shift points up because stock you should shift at 6k???
Old Apr 15, 2011 | 08:56 AM
im not exactly sure what he did in the tune....i read up that the stock rev point was 6200? not even sure the guy did it right. he had a mustang dyno and all that i saw at his place was mustangs. i have the cam lts catless ypipe and some small boltons that dont do much and he dynoed it at 326?
Old Apr 15, 2011 | 09:00 AM
so if the guy didnt tune out the rear o2s will this effect my car then?
Old Apr 15, 2011 | 09:08 AM
Funkster's Avatar
Other than an SES light no.
All the rear o2s do is monitor catalytic converter function.
Old Apr 15, 2011 | 02:19 PM
lol i just remembered that i have one of the front o2 plugged in the back plug and i have a front plug not plugged in
Old Apr 15, 2011 | 02:24 PM
85CamaroZ28's Avatar
You have a cam and dyno'd 326? What cam?
Old Apr 15, 2011 | 02:30 PM
its a 216/224 crane cam with comp lifters
