how to do a burnout in a auto
I notice when i go to do a burnout yes tc is off.i step on my brake pedal and then gas its seems to hold my rpms down.the only thing maybe i can think of the car was in open loop but i believe i did it from coming back from an 2 hr ride and it did the same ****.no i dont have line loc.yes i know its a little hard on breaks so what there going to wear out anyway
You should be able to apply some brake and then slowly ease into the throttle. If you start moving you can apply more brake pressure until you're frying your tires. It could be an issue with torque management or some other trans problem if you can't... even a stock A4 should be able to roast the tires no sweat. I can do it in my '02 Z28 A4 without any problems and I'm still running a stock stall.
floor it and its not gonna sit there and spin which is what hes wanting judging by his post. Have you tried to floor it first getting some spin started then putting on the brakes?
This was when I was Stock, Lid, 3600 Stall, No tune, and street tires. That was it.
You can ROAST! them, if you look closely, I was even burning them out in 2nd, when I let off.
prob going into 2nd gear and bogging down...
wot that mother in first gear on the brakes, let it tap the rev limiter one good time at least, then switch to 2nd and let off the brake and hold it wide open. It will waste your tires
this car had a 5.3 swap and 20x10s on the back
http://www.youtube.com/watch?v=O_oKJ-5ymVw
this one had a 5.3 too...and it would rip them off
http://www.youtube.com/watch?v=8P0X89d8Sd4
hell f bodies do better than this....
Just hammer on it..
http://www.youtube.com/watch?v=ULJISQgIQdQ
That was the old setup..the MCSS will leave rubber all over the place..
That first 2 ft was in 1st..lol..the rest was in 2nd.
