Lq4 or lq9
I have an engine from a 2003 Denali and was told it was an lq9 from a local salvage yard. The engine is now in my trans am with 10,000 miles driving on it. I'm about to do a cam swap. It does have 317 heads.
Is there any way to tell the difference between the two engines with out removing the heads?
Yes it says 6.0 on the block but all iron 6.0 do. They are the same block. So far the only way I can find to tell the difference is to pull the heads.
My problem is I have a ms4 and with 9.5:1 compression it would be a dog. I do have a set of 241 from the original engine and a pair of 706 fully cnc ported but I don't think those heads are enough for that size of cam. Although either will bump compression I just don't think either head will flow well enough for that large of camshaft.
I used a snap on camera scope and found out it is an lq4. So now comes how to make my cnc ported 706 heads work on that block. Hopfully with a ms4. I researched fly cuting last night and it didn't look bad.
Also I started a thread in gen lll internal engine.
From my measurement the 5.3 have been milled seven thou. I was wondering if I could use a thicker gasket to make up the difference. Ive some about quench but it should be fine I would think if the gasket is 9 thousandth thicker then stock and the head mill is 7 thousandth
Having a fresh valve job performed will require a regrind on the valves and
seats which will move the valve north (away from piston) enough to comp-
ensate for the .007" mill. The 56 thousandths MLS gaskets give about .048"
quench clearance. Also are those heads set up w/2.0" intakes ?? This would
also help w/clearance as opposed to 2.02/2.04 which can interfere with the
edge of the piston dish.
