stock running temp?
My thermostat went bad and started leaking an absurd amount of coolant. I just replaced it and topped off the coolant took it for a ride and now i cant remember exactly where the stock temp would run. Im running a little under 210 i feel like that is a tad higher than what it was but im not sure if my mind is playing tricks on me.
I assume from your sig that you have a 2002? If so unless you have a aftermarket temp gauge, the factory gauge is a dummy gauge. It really only shows 3 things, Cold, normal, and overheating (meaning there not accurate). 1998's were the only f bodies with accurate temp gauges.
