6.0L LQ4 ARP Rod Bolt Swap
I have a 2001 6.0L LQ4 that I've put in a 1952 Chevrolet Pickup, with a 4L80 trans behind it. Engine and Trans modifications so far:
-Custom grind Comp Cam
-.700 lift valve springs
-Hardened Pushrods
-High volume oil pump
-LS1 intake w/ stock TB
-Holley EFI Fuel Rails
-FAST 38# fuel injectors
-2010 Camaro Water Pump
-Custom accessory brackets from LSbrackets.com
-Hummer H3 Alpha Oil pan, Pickup Tube and Windage Tray for frame clearance
-ARP Rod Bolts
-3200-3400 Stall Torque Converter
-LS2 Timing Set
So, here's my question. I've heard the rumors about the ARP Rod Bolt install. Some say you're supposed to re-size your rods and main caps... Others I've talked to say that I should be ok, and shouldn't have to do any further mods. Just looking for some feed back guys... Thanks!
-Hardened Pushrods
-ARP Rod Bolts
-LS2 Timing Set
It's a crap shoot. Some are lucky, others not so much. I've done and measured a few sets. The ones I replaced in my car without resizing went .003 out of round. I did a few other sets I had laying around just to see what would happen and they all went out of round between .002 and .004.
These were all with arp bolts.
I did 1 set with the katech bolts recently and they went out as well. Only by .0015 but they were still out.
I would re size them if you plan to go that way.
So why does a stock bolt not put the cap end out of round?
Why does the arp bolt warp the same end until its out of spec-junk?
Does the engine factory have a special rod cap installation tool designed to keep the big end round?
Didn't mean to start an argument fellas. I appreciate the info though. I guess we're gonna run with the ARP's without re-sizing for now. The second I feel a vibration, I'll be re-sizing and replacing some bearings as well. Just want to get the truck rolling and get the bugs worked out first. Thanks!
