Is my cam to big?
wassup fellas, I have a Fuel injected 454 lsx with a 257/266 .646/.646 on a 114+4. I am not 100% sure it is the cams fault so is why im posting this.
My car can pretty much never start up (cold start) by just turning the key. I always have to give it gas like if it were carburated, otherwise if not it will just crank over and die almost instantly.
Also, even after warmed up, when i take it out of park and put it into gear, the rpm's will sort of surge and fluctuate.
Also, it cannot be driven normally sometimes. meaning; i cant just give it gas and go. I sometimes have to slowly and lightly give it gas until it reaches about 1500 rpm before it acts normal. if i dont do this, it will hesitate real bad, then all of a sudden surge up real quick.
if im at a stop light and floor it, it will hesitate real bad before getting up and going. sometimes at a stop light the rpm will drop so low i have to give it gas to keep it alive.
is this common with big cams? it it the tune? or maybe something else. any ideas??
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
There's tuners, and there's tuners, and few of them
want to spend the time needed to get cold starts
and idle right - nor would you want to pay shop rates
for the time it takes.
Now, yes, you have to accept some compromises in
drivability as a consequence of "going big". But how
much better it could be, you may never know "by the
hour".
hour".
I actually have a guy who has tuned numerous cars and can come to my house to see cold start. after i get my 4l80 in the car im going to purchase a wideband and have him see what its doing at cold start and light throttle.
Someone mentioned you have to swap 2 wires on the ls2 extention harness. The previous owner of this motor said he doesnt recall doing this. would not swapping those 2 wires on the ls2 extension harness have something to do with this?
The motor is from LME and was setup to be in a f body. 24x tooth reluctor and all the LS2 stuff like the timing cover and valley cover. But someone mentioned swapping 2 wires on the extention harness
