General LSX Automobile Discussion Non-technical LSX related topics.
checking for spark on LS1?
Old May 1, 2013 | 07:32 PM
Ron_Stoppable's Avatar
Default checking for spark on LS1?
i want to make sure im getting spark and was just wondering if i could do it the traditional way by placing the sparkplug threads on the side of the head while someone cranks the engine? i just dont want to get shocked.. lol
Old May 2, 2013 | 01:18 AM
jimmyblue's Avatar
Moderator
I prefer an inductive pickup, clamp-on timing light
for that.
Old May 2, 2013 | 02:09 AM
but would i still be able to see spark if i just grounded it to the head? im trying to figure out why it wont start. i know im not getting fuel past the injectors for sure. they sat for a LONG while but i boiled them for about 20 mins and that got alot of crud out. my question is even though the motor isnt firing up, would the porcelin portion of the sparkplug near the tip still have brown marks if the plugs were igniting but the motor not being started? my plugs were brand new but i pulled them and looked at em and they have brown marks on em
Old May 2, 2013 | 02:29 AM
roninsonic's Avatar
hold the plug in your hand, stick the other one on something metal, and have someone crank it for you. You'll KNOW if you have spark
I'm actually NOT being a smartass... It's what I wind up doing half the time.
Old May 2, 2013 | 05:56 AM
Gregory's Avatar
If I remember correctly, holding the gas pedal all the way to the floor while cranking prevents the LS engine from starting and flooding. I do not know if this kills the spark and/or fuel, but if you have a second person, you can try it.
Old May 2, 2013 | 10:56 AM
i pulled the plug after trying to start it.. even if the motor doesnt run, is the plug capable of having these marks from igniting? they were brand new when i put em in. ( on the insulator)
Old May 9, 2013 | 06:24 PM
but seriously though i can just put the plug up to the cylinder head while someone cranks the engine right?
Old May 10, 2013 | 01:58 AM
Gregory's Avatar
Sure, you could do that. You could also use a Volt/Ohm meter, or the timing light like Jimmy said.
Old May 15, 2013 | 12:21 PM
LSPOWEREDS10's Avatar
Pull the plug wire from the coil to check the coil leave the wire close to the coil so it will still make contact get someone to crank it if it sparks its good next plug the coil to the wire then pull the wire off of the plug leave it close by so it will still make contact crank it again if it sparks the wire is good next unscrew the plug from the head connect it to the wire and crank get some one to crank it if it sparks then its good
