Car smokes on decel after a pull
Hey guys wondering if you could help me identify whats going on...
The car smokes a little bit on decel after a pull. Never happens on start up, idle, or regular driving, only when i beat on it.
Mods are in sig
Any ideas?
Thanks
Mods are in sig
Any ideas?
Thanks
Moderator
If you're lucky, valve stem seals alone could do it
and can be installed from the top, no teardown.
Just have to pull the springs and keep the valves from
dropping (rope trick?).
It's cheap to try, at least - if it helps only temporarily
(like until seals harden some) then you'd have to
pull heads and get fresh guides (and perhaps dress
them with the die grinder if you had ported heads).
