Oiling the K&N air filter
So I bought the cleaner kit and I oiled both sides by mistake. I was able to wipe off most of the oil from the side that faces the MAF and havent had any issues. My question is should I just re-clean the whole filter?
Or throw it away and go paper
I just oiled mine up pretty good on both sides... Doesn't say in the directions not to spray both sides. It actually says after letting it "wick" for 20 minutes to touch it up on both sides till its nice and red all around... I guess if theres too much it'll get sucked off the filter and into the MAF..?
I wouldn't worry too much about it. You've wiped off the excess.
If you have some trouble down the line get a good aerosol electrical component cleaner and shoot the MAF's wires to clean them.
Worst trhing you can do to any engine is put one of those DIRT DELIEVERY K&N ANTIFILTERS in. They have worn-ruined many engines. COMPLETE JUNK!
I want to tell you a little story about a low mileage Corvette that had INSANE oil usage problem. Guy tossed the factory air filter when the vette was new and installed the K&N. By 30k he was back at the dealer with major oil usage problems, we pulled the heads off. ALL the cylinders, pistons and rings were WORN OUT. The K&N allowed so much dirt by even the inside of the intake was coated with road dirt!
****** JUNK!
****** JUNK!
****** JUNK!
****** JUNK!
Haters gonna hate.
Over oiling a filter will coat the MAF sensor with oil - just remove and clean with electronic cleaner spray.
Regarding paper vs. higher flowing filters. Install a high flow filter and the entire idle of the car changes. there is a definate difference on air flow and motor loves it. Is it good in the long run, I guess not
