Wheel hop.
BMR non-adjustable lower control arms (TCA001)
BMR bolt-in lower control arm relocation brackets (CAB002)
If there is anything we can help you out with just let us know.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Generally most of our sales happen around the end of the year during the holidays but get with me when you are ready for them and I will make sure we get you taken care of.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Bad shocks will also cause wheel hop, But since you said getting sideways and doing doughnuts you might want to refrain from those unless you intend to replace the 10bolt in the very very near future.
Chances are the shocks are bad....go push down on the hatch, if it bounces like a lowrider change the shocks first. That's what was wrong with mine. Just curious where are you located.....Cali? Los Angeles?
The car is lowered, I didn't do it myself when I bought the car the guy said the rear shocks where compressed. To give it the lowered look.
I am not sure what the guy meant by saying that the rear shocks were compressed but if the shocks have a bunch of mileage then they could be an issue also. But since the car is lowered I can tell you for sure that the lower control arm angle is off but can easily be fixed with the relocation brackets.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
You don't need relocation brackets because your car was lowered... my car is lowered a little over an inch and with just good Bilstein shocks and 1LE style LCA bushings I got rid of all my wheelhop.
There are plenty of people lowered with stock LCAs that have no wheelhop problems, myself included.
Another issue to look at it is wheels and tires. He's running a 19 inch wheel... which is most likely very heavy and makes the shocks (which are probably 14 year old Decarbons that are totally worn out) work even harder to keep the axle under control. AND the tire has very little sidewall to absorb the shock of dumping the clutch. This guy doesn't need to spend money on parts that are meant for drag cars... first things first, look at a proper spring/shock combo (not "compressed shocks for that lowered look" as he said the previous owner claimed), switch out old dry rotted bushings, and also put a properly sized wheel/tire setup on the car.
All valid points^^ I was just speaking from experience...a lowered car will have neg. LCA angle (potentially increasing wheel hop for a 'clutch dumping, donut cutting OP). My car is lowered with LCA RB in lowest hole and it plants the **** out of the tires w/stock LCA's. I was merely suggesting a best-bang-for-the-buck for the OP to consider.
Although I would bet that the single biggest cause of wheel hop for the OP is that wheel and tire setup... heavy wheels plus low profile tires is not going to perform anything like stock.
