General LSX Automobile Discussion Non-technical LSX related topics.
Howards ASA cam numbers
Old 06-09-2017, 02:55 PM
SarGntoperez's Avatar
Originally Posted by tech@WS6store
Lift has little to do with the actual ramp profile of the lobe and how aggressive it is. Use the pac1218 and not worry so much.
pac 1218 are good for .600 lift I see theres a Howard's valve springs good to ,.600 lift which ones are better?
Old 06-09-2017, 03:02 PM
LS1Tech Premium Sponsor
tech@WS6store's Avatar
The howards is possibly made by pac. check the spring specs and if they are the same then use the one that is less $$ id say BUT the other fact is Pac makes their own springs...howards does not...so keep that in mind. our 1218s are $139 shipped.
Old 06-09-2017, 03:27 PM
I was thinking of getting pac 1218 ima conprare pac vs Howard's, but most likely pac 1318 is the best choice. My buddy told me that with the Howard's asa I can ise the ls6 blue springs what you think?
Old 06-09-2017, 03:32 PM
The blue arent as good as yellow were, but i never recommend either for any cam. 1218 is where i start.
Old 02-07-2019, 10:56 AM
dawgs74's Avatar
I just added a power brake booster to my 68 c10.....will my asa cam be ok with that....or do I need to run a vacuum storage tank?
Old 02-08-2019, 04:45 AM
JadXtreme's Avatar
May need the tank but you might be ok depending on what your idle is set at. My G8 would try to push or have squishy brakes sometimes at idle. But I have a stock stall too. Just try it out and see, may be just fine.
Quick Reply: Howards ASA cam numbers
