Slp dual dual with ring of silence
Anyone have the slp dual dual and came with the rinh of silesilence, of yours had it, how did you removed it and where exactly is it located
yes some of the 98-02 with slp dual dual catback came with a ring of silence not all only some, supposedly is in the driver side where the tail pipe conncets to the muffler inlet, I've read that if your tail pipe is cleaner than the other one then you have it or if it throws less air from the other one, the ring of silence reduces the restriction of the inside of the pipe to make it quieter supposedly
My understanding is if the SLP Dual / Dual was purchased directly from SLP it didn't have the Ring of Silence. The SLP Dual /Dual I bought direct that's on my TA didn't have a RoS.
The SLP D/D 's that came on the car as an installed option or part of the Firehawk package often have the RoS. I'm not sure of when the RoS was added. I think it was added due to a noise standard at some point during 4th gen fbody production.
The used SLP Dual /Dual on my 91RS had the RoS removed by the prior owner. When he added different tips. iIRC he said it was on the driver side.
Yes thats what I underetood too only some came with it, the one i just bought was tsken off a camaro ss idk about the year tho, so if it has the RoS it should be on the driver side then?
Slp dual dual
