Identifying Fake NGK Spark Plugs
I figure I would put a little PSA out there about identifying fake NGK spark plugs. There is already information out there, but some of it is outdated as these clowns try to make a better copies (in looks, not performance). This is a comparison between TR5IX plugs I picked up on eBay for $38 shipped and plugs I bought at Advance Auto for $54 after a $5 rewards coupon and a 25% discount. So, the price difference isn't that drastic. Here is the ad on eBay:
For anyone who has spent ten minutes on the internet before, the ad does look suspect. Typically, anything that is advertised as "USA shipping" or puts the word "For" in front of the item your looking to buy should be avoided. However, as you will see, they did use real NGK plugs for the pictures. It should be noted that these plugs are also sold on Amazon.
The sad thing is that the average person isn't going to have another set of NGK plugs to compare the fakes against, and if you just have these plugs in your hands, you may not know the difference. However, the subterfuge disappears quickly when you do have a real set to compare against. For the following pictures, the real NGKs are on the left and the fakes are on the right.
The logo is much larger and the entire box is much brighter on the left. Notice how the spark plug on the fake box has a blue tint to it, and the color transitions aren't nearly as defined:
The dead giveaway is the letter spacing of the model number. The real box has the letters much more condensed and the fakes have gaps that you could kick a field goal through. The "NGK" is a much brighter red on the real box, and the bar code itself is larger. The font for "Iridium IX" is also different.
The back of the boxes show further distinctions. The fake box's white background looks like an undershirt that was never separated for laundry day. The wording in the bottom right is completely different, as well.
Stark bar code differences, and the real box's colors are much brighter with the transitions much more clearly defined.
The smaller plug box is no different, with the fake plug completely washed in blue.
The same letter spacing carried onto the smaller box. Notice the letter spacing in the ad's pictures matches the spacing of the real NGKs.
Bar code and font differences. Again, not something you would pick up on without having a real version to compare to.
More subtle differences.
Onto the plugs themselves. The cardboard sleeve isn't a dead giveaway as I has just installed some TR6IXs from Advance in the GTO, and they had cardboard sleeves. However, the printing is definitely much more distinct on the real plug. Also, NGK has replaced "NGK Japan" on the hex with "Assembled in the US from Japanese parts."
The plug ends on the real NGKs are definitely a higher quality with much better defined transitions.
True NGKs have a noticeable dimple, whereas the fakes do not:
Here is where things get critical. Look at the difference between the true NGK iridium tip and the fake iridium tip. One of the major benefits of iridium plugs is the narrow electrode. I would also highly doubt that the tip is actually iridium. Another critical difference is the length of the ceramic insulator. Both plugs are supposed to be the same heat range, but the fake's insulator length would suggest that it is a colder plug than a true TR5IX. It looks like it could be a heat range of 6 or possibly even 7. Further down, you can see the difference in quality of the thread cuts and the taper seats.
The ground electrodes are completely different in shape and size, as well.
Where the ceramic inserts into the hex, you can see the real NGKs have a powder whereas the fakes have a sloppy sealant of some sort. The sloppiness wasn't on all of the fake plugs, but the powder wasn't on any of them.
So, there is my comparison between the two. I've seen a couple videos and other posts highlighting differences, but I figured I would add to the collection using plugs that I acquired in 2021. Having just the fakes in your hand, not many people would know the difference. Hopefully, this will help people verify if their plug is authentic or not. I would say that your safest bet is to get your plugs from a trusted source such as Rock Auto, Advance, O'Reilly's, etc. However, I would still caution to double check the plugs you get, because I wouldn't put it beyond someone to buy real plugs and return the fakes just to have the parts store toss them back on the shelf for the next person to buy.
The following 2 users liked this post by MuhThugga:
RedXray (05-05-2021), Woodylyf767 (05-05-2021)
LS1Tech Administrator
Received 1,792 Likes
Great thread, great illustration of the differences. Thank you for sharing. I've always bought mine from NAPA or other trusted retailers, so I never really worried about fakes, but you make a good point about the possibility of fakes being returned and then unknowingly resold from an otherwise trusted source.
Appreciate the detailed write up! Good information here folks!
Well dang dude, now you got me wondering what I just put in my truck last month.
Funny thing is, the size of the logo, spacing of the lettering on the main box and individual boxes, all looks like what you show of the left for TR6IXs. But the back of the box lettering on the corner, the bar codes, and "made in Japan" match what you show on the right. Mine also used cardboard protection sleeves.
From what I recall, the threads were really shiny on mine, and I remember noting how tiny the electrode was (first time using NGKs). So hopefully the parts are the real deal. I bought mine off Amazon. Price was ok, but not amazing.
Edit: well this is what I found. Looks legit.
From what I recall, the threads were really shiny on mine, and I remember noting how tiny the electrode was (first time using NGKs). So hopefully the parts are the real deal. I bought mine off Amazon. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Price was ok, but not amazing.
I’m sticking this one...
Just to add to this, I decided to weigh each individual plug in one of the 4-packs. The real NGKs all weighed in at 40 grams.
Three of the fake plugs weighed in at 39 grams, and one of them weighed in at 38 grams.
This isn't to say that all authentic NGK plugs will weigh in at 40 grams, but it does suggest that all authentic NGK plugs will have a consistent weight.
I also contacted NGK, and they were able to verify the counterfeits over the phone using the 4 digit code on the hex. The counterfeits have the code "C9YA." NGK said they are definitely counterfeit because the C stands for "China," and none of their US market plugs have that designation. The authentic plugs have the code V111, indicating that they are made in Virginia. NGK said that the plugs can come from Japan, the US, or Taiwan, but never China. So, if you have NGK plugs with a "Cxxx" code stamped on the hex, it is a dead giveaway to being fake.
Ah hah! Weight savings! The fake plugs are good for something.
Br7ef
Just checking if there are any fake BR7EF I have to worry about?? Thx!
