LQ4 Truck Pulling Motor Advice!
Hey all. First time posting here so sorry if i get anything wrong. I have an 04 silverado 2500LD that im building into a sled puller for this season. The powerplant is ofcourse an LQ4 paired with a 4l80e. Im looking for some advice or directioning on:
1.what size of valve spring/brand of spring should i go for?
2. Do i need to do any oil/timing chain upgrades?
3. Do i need trunions or valvetrain upgrades?
4. Any and all methods of cheap power gains are much approved
5. Water meth is in the back of my mind but is it worth it on an N/A motor?
6. Is it worth it for me to get HPTuners?
The motor rules are as follows:
1. 500cubic inch max
2. OEM cast block, aluminum or cast OEM heads, OEM intake and exhaust manifolds
3. Sfi balancer or balancer shield
4. Electric fans ONLY
5. Must be "gasoline" fuel only, injected in oem location.
6. N/A only
Currently the motor is at around 200,000KM (125,000miles) and is stock besides an intake, duals dumped after the cab with no cats and a cheap OBD 91 octane tune.
my parts list so far are as follows:
BTR STAGE 3 TRUCK CAM: lift .552/.552, dur @ .50 218/224 LSA 113.0
GEN 4 (TBSS) Intake off of an LY5
GEN 4 Flex Fuel Injectors (NOT DECAPPED)
GEN 3 to GEN 4 throttle body adapter plate.
Truck will run at WOT for about 30 seconds each run (1st gear, 4lo, tow haul on). Otherwise itll idle around. RPM limit is currently factory but ive looked at doing a 2 step rpm limit due to how slow the stock one drops. Any and all advice greatly appreciated!
6. N/A only
No point in meth injection on a low compression N/A application. I have a 2006 2500HD with a 6.0, and that thing is a pig. You're going to need all the help you can get. I'd use a BTR Truck Norris cam over the one you picked, just for the increase in midrange torque. You're pulling weight, you want all the torque you can get. 317 heads are the worst for compression/quench, I'd slap a set of 706/862 heads on there, it will bump your compression by a point and you'll pick up power. Regardless of the drop in intake valve size. Even if you're wide open the whole time, a cam with more overlap is going to help you fill the cylinders. If you don't plan on building the bottom end, you probably don't need to touch the oil pump either. Trunion upgrades are always good, and BTR has good spring packages as well. They make a no springs required Truck Norris cam too, but I'd at least slap a set of LS6 springs on there. If you have zero experience with tuning, just buying HP Tuners might do you more harm than good. By the time you pay for it, the credits, and a wideband O2, you could have a dyno tune done.
i helped a friend make a 04 2500hd reg cab 5 spd pull truck, a tsp 228/228 110lsa cam kit w- springs and push rods, tbss intake, tsp 1 7/8 headers then went 4.56 or 4.88 gears (cant reamber at the moment) and it did very well in its class. yes you need to have it tuned by someone that knows what there doing , 6500 rpm limit should be fine you dont want to be 3/4 track and bouncing off limiter. if our budget was higher we would have bored and stroked it to get more cubes and got the compression to around 11.5 or so and just sent the 317s off for port/polish work. one other thing to look at is the front suspension set up, it needs to transfer weight really well think less torsion pressure and limiter straps. youll have to play with it alot to get it to track straight (i know we did) also we hid alot of weight behind the front bumper , you can get really creative in low class truck pulling id suggest getting the rule book and look for ways to maximize your set up, HP is good but a well set up truck can go very far. any way happy wrenching sir.
I can do any internals so long as its the oem cast block.
Is there such thing as too much spring lift? Theres a set of .700" springs forsale but i wasnt sure if thats too much for the size of cam/stock valves.
It's not the lift capacity that causes issues, it's the seat and open pressures. If you don't have a cam to take advantage of them, the stiffer springs eat power and can be harder on your valvetrain. Get the lightest capacity spring that will fully control your valvetrain without going into valve float or valve bounce. Always consult the cam manufacturer on what springs they recommend for their specific grinds. I don't think LS7 manifolds would work in these body styles of truck - They're center dump and will interfere with the frame/steering shaft, IIRC.
Spring specs are:
lift: .625"
seat press: 125lbs
open pressure: 367lbs
installed height: 1.800inch
Open height: 1.150inch
spring rate: 372lbs inch/hour
is that like an "average or low" capacity? And at 1.800inch would i not need new pushrods aswell?
That's a middle of the road spring, and you can get a better BTR spring kit for less: https://briantooleyracing.com/catalo.../view/id/58362 You will have to measure for pushrods no matter what, because the base circle on the cam may be smaller or some component tolerances might be different and things will shift. It's not a difficult task, especially if you're planning on using the stock valves in the heads.
If ya dont mind me asking, where did you guys get the gear sets for the front and rear diff? The trucks got 3.73s but i would love more reduction to compensate for the lower power. As of right now the trucks actually overweight. (5600lb max, trucks currently 5890 with me in it) so im gutting the bed and interior soon. Are welded/locked diffs good? I know the g80 has that weak speed controlled LSD in the rear (not sure about front). As of right now, i have the front keys cranked down all the way, with a set of homemade tierod sleeves, and leaf clamps in the rear that bend the overloads up to the other leafs.
Yessir the truck is very not streetable anymore haha. Thanks. Now ive got alot of research to do about diffs and gearing (i know nothing but the basics lol)
Lol ive been looking into it all evening. At the moment im trying to figure out what the exact rear axle i have/front diff in order to size the correct parts lol. Im new to this 😂
should be 9.25 ifs front 10.5 14 bolt rear.
