Guaging price to ask - Highly modded 1998 Camaro Z28
I am debating selling my Camaro but want to figure out what it's worth. If you were in the market for a muscle car, what price would you put on the following:
1998 Camaro Z28
79xxx Km's / 49xxxx miles
6 speed T56 trans with Pro 5.0 short shifter
3.73 gears with zexel torsen posi and TA rear end support girdle
3 aftermarket electric fans
Powerdyne 6 lb supercharger with custom air intake
Ported composite MAF ends
LS6 intake manifold
38 lb injectors
Added high flow inline fuel pump
10mm spark plug wires with NGK plugs
Lingenfelter GT2-3 camshaft
Aftermarket valve springs with chrome moly pushrods
Mac 1 3/4" ceramic coated headers with custom Y pipe including 2 Random Technology high flow 2.5" cats
Mufflex 4" mandrel bent exhaust system
ported throttle body with coolant bypass mod
160 hypertech thermostat
customer programming with LS1 edit
Dynojet wide band O2 sensor system with logging
Custom alcohol/water progressive alcohol injection system
17 x 9.5 chrome Z06 wheels with Nitto Drag radials on back
SLP Ultra Z composite hood
Brushed stainless steel door sills covers
Leather heated seats
Subwoofer and amp
1LE Front & Rear sway bars
Spohn LCA's
Spohn PHR
Random Technology adjustable torque arm
Kenny Brown double diamond subframe connectors
Hotchkis strut tower brace
Bilstein HD shocks and struts
KVR cross drilled rotors
Earls braided brake lines
Custom line lock
Options:
OEM chrome 16" wheels and tires
OEM aluminum 16" wheels
The car dynoed at 420 HP at the rear wheels
1998 Camaro Z28
LS6 intake manifold
38 lb injectors
Subwoofer and amp
Spohn LCA's
Spohn PHR
Custom line lock
Options:
I'd pay $13 thou for it. That's a SERIOUS mod list, so hopefully you're selling to an enthusiast who wants at least half those mods and FI (I do). Only thing going for it is its relatively low mileage for the year.
