oil change light?
oil change light appears when i start the car and lasts about 1 min then goes off. the oil is fine its only got 1500 miles on it so it doesn't need to be changed. im not very familiar with the ls1's i had a 96 3.8l 6 before so maybe this is something its supose to do or maybe because its cold its doing it.
if urs is like mine then after u change the oil u turn the key to the on position without starting the car and hold the trip/odometer switch down for i think its 7 or so seconds and it will go out. if u change ur oil cause u see the light then u need to reset it after u change it, it will not shut off automatically after u change it.
'Bird Director
Originally Posted by B.W.
You just need to tell the computer that the oil has been changed. Look in your owners manual. You either hold the trip odometer button for 7 seconds or pump the gas pedal 5 times in 3 seconds with the key in the 'acc on' position or something like that.
Originally Posted by SS#2906
Not sure if I saw anyone ask, but what weight are you using?????
It may be too heavy, or too light.
Originally Posted by gyrene2003
..........this is off topic but i thought 96s had 3.4s not 3.8s?
