General LSX Automobile Discussion Non-technical LSX related topics.
Who has the highest HP Street Driven F-bodie
Old 02-10-2007, 03:53 PM
ls1chris's Avatar
Default Who has the highest HP Street Driven F-bodie
well im sittin here at work today and i just got to thinking what is the most hp that you have seen or heard of being daily driven. I rememer i think a guy on here had a 1000 hp trans am twin turbo that he daily drove .So come on lets see some pics if you can and mod list
Old 02-10-2007, 04:31 PM
NKAWTG...N
StoleIt's Avatar
Intmd8t (i think thats his sn) has a Twin Turbo Lt1 with 900/900+. That has AC and everything. Couple other turbo cars too that might be daily driven. And I am sure there are a bunch of N20 cars out there as well.
Old 02-10-2007, 05:57 PM
99Z28LS1's Avatar
i say Tiago, i was told he's on twins close to a 1k
Old 02-10-2007, 06:38 PM
BLNLS1/RX7's Avatar
1999 Z28 Camaro 382 Cu.IN. LS1 Stroker Motor ,Callies Stroker Crank,Callies compstar rods.Diamond pistons,Total seal rings,Stud girdle,ARP Head studs,SLP oil pump,Comp cam,Lingenfelter Heads,LS6 intake,Spec3+ clutch,Billett flywhell,T-56 transmission,SLP longtube headers,Siemen 60lb. injectors NX direct port 300 shot nitrous.792 RWHP 835 Torque.Will post pictures when it stops snowing long enough for the streets to dry out.
Old 02-10-2007, 06:40 PM
kidcamaro98's Avatar
yah Tiago made like 998rwhp or something like that....Twin turbo T70 trans am...its badass. He turns the boost down tho on the street to 850rwhp
hes got his dyno video on fquick.com
Old 02-10-2007, 07:12 PM
Allergik2dyin's Avatar
I'm sure there a few guys on here with 800+rwhp that claim to be dd's. But what do you mean by a dd? Some people consider that to be their only car and means of transportation. I doubt guys with 800+hp monsters drive their car to work and for errands etc., although I'm sure there are a select few that do. But overall, people with cars making that kind of power drive them a few times a month, not as a true DD, but maybe I'm wrong. Either way they are some badass cars.
Old 02-10-2007, 07:33 PM
LS1>girlfriend's Avatar
gmhtp did an article on mighty mouse. his formula made 995 rwhp and 1000rwtq on a chassis dyno with a single pte 88mm. he drives it to work and back
btw he's got a t-56 and a moser 12 bolt handling all that power!!
Old 02-10-2007, 07:36 PM
Administrator
unit213's Avatar
You mean...drove.
Old 02-10-2007, 07:48 PM
yes yes, drove
Old 02-10-2007, 07:49 PM
Administrator
unit213's Avatar
yes yes, drove
I concur.
Old 02-10-2007, 09:27 PM
ls1chris's Avatar
yes i should have been more clear i know it would be hard to drive a 1 k horesepower car daily but just that is still streetable like tiagos or mighty mouse...those was the two that i had in mind..Hey Unit how about you i thaught you was in the 600 range with your cobra and was thinking of spraying it
Old 02-11-2007, 05:30 AM
darrensls1's Avatar
I would have to question the sanity of anyone who drove a 800+ rwhp car as a true "daily driver". If someone has 15-30K for mods then I'm sure they could squeeze out another grand or two for a beater to drive to work and back.
So I agree with you. But I consider street driven and daily driver to be two different things all together. There are lots of street driven monsters out there and to them I
Old 02-11-2007, 06:31 AM
Genesis_26317's Avatar
I think that DD driven means that they use the car for everthing. Including 800 mile vacations, grocery store runs, driving the car in the rain AND snow, going to work (aka real work not to a auto shop), and also driving their mother to the hospital when she is having a heart attack.
If you own another vehicle that is used for anything other than off-roading or specialized for crap like hauling horses than your 1000 hp beast isn't a daily driver like the regular world considers it.
If you can sit and put-put in a car with 3.73 gears and 1000 hp on a hour-and-a-half long drive 10 miles to work than how the hell do you afford gas???
BTW in Austin it took almost two hours for me to drive 22 miles to class every morning before North-183 was reopened, I spent over 90 dollars a week on gas and I only drove my Camaro ~175 miles.
Now that is a test for any car to be called a daily driver!
Old 02-11-2007, 08:10 AM
Administrator
unit213's Avatar
It's in the works. More boost, more fuel sustem mods, good sized shot
of nitrous. I'm expecting 800rwhp or so. My car is no longer a daily driver though.
Old 02-11-2007, 08:21 AM
Moderator
davered00ss's Avatar
PUR EVL is daily driven. Weekend cruiser. I know he is somewhere in the 900+ rwhp.
Moderator
I've been in that car it is SCARRY.
Old 02-11-2007, 08:47 AM
blackfang's Avatar
Yes David has dynoed 995 rwhp on his full weight and daily driven car. I believe he drove the 200+ miles to a dragstrip and cracked 9's when he became the first FI 6 speed LS1 in the 9's 3 years ago. I have seen the interior many times while at a hangout together or at the track. That car had full interior and everything.He drove the car to work, to the track and on trips.
However he did have a tragedy last fall while at the track, but the new car will be running the same motor and setup but I believe David is now running a stalled auto.
Old 02-11-2007, 02:23 PM
ls1chris's Avatar
ya unit you will have to post up some more vis when you up the boost that thing screams already.But as long as you can still drive it on the street sometime thats all that matters .WOW alot of ppl have cracked on the 7-9oo hp mark well done guys
Old 02-11-2007, 09:51 PM
Yeah I agree with you, I just thought I'd point out that it would very hard to truly DD a 900+rwhp car. Street driven is a much better way to put it. But still...badass cars
Old 02-11-2007, 11:09 PM
Starz T/A 17's Avatar
It wouldnt be that hard to do if you have the $$$$$, best way to go about it would be either with a turbo or N20 b/c you dont have to spray all the time and with a turbo you can lower the boost. And for what you consider street drivin is another thing, IMO if your talkin about records and such a street drivin car should be able to pass inspections without knowing someone who will overlook crap just my 2 cents
