How much fuel should you keep in the tank to cool the fuel pump?
My Dad is always screaming and hollering about this.
Originally Posted by oneBADDz
never get below 1/4 tank for several reasons. Any fuel at all (enough to keep running) is enough to cool it though
It's all BS. The forth gen f-body draws fuel from the tank into a bucket that holds about a quart of fuel. From there it's pumped to the engine. Fuel returning from the engine is also dumped back into the bucket so it remains full at all times regardless of how much fuel is in the tank. Because the fuel pump is located in the bucket it stays sumerged in fuel at all times.
People who say they never let their car run below 1/4 tank so the pump dosn't pick up crap off the bottom of the tank are also full of crap. Any crap that is in your tank will always settle to the bottom, and regardless of how much fuel is in the tank the fuel pickup ALWAYS draws fuel from the bottom of the tank.
Re'
Re'
One reason is because on top of the fuel gauges in these cars not being accurate to start with, they don't quite seem to all run the same. I have heard some stories of guys running out at 1/4 tank (on the gauge), yet others, including myself, have a couple gallons left at that point Though that is a little closer to empty than one should be in the first place with an in-tank fuel pump. Case in point: A bit past full = full, 1/2 = 1/4, 1/4 = GET YOUR *** TO A FUEL PUMP. Note that those are rough measurements.
I never let my car go below 1/4 tank, thats just how I am though I feel like I'm gonna run out of gas if it goes lower. My gauge also moves back and forth a little once it passes 1/4. But my grandfather did ruin the fp in his s10 running around close to empty.
Re'
Re'
Originally Posted by nighthawk15
Never heard this before. If it's true I wonder where the myths come from. However I still wouldn't drop below 1/4. That's only a couple gallons left in the tank. Lil too close IMO.
The pump in my wifes mini van failed when the tank was full by picking up a small rock off the bottom of the tank. Nothing like dropping a 25 gallon tank full.
Re'
Nobody said that they ONLY fail when they are empty. Nobody said that if you run low/out of gas that your pump WILL fail. Whether you like it or not though, running out of fuel can and does contribute to pump failure in many cases
Does anyone know how much fuel is left in the tank when the check gages light comes on. I have heard, let me emphasize heard, that you had 18 miles left. I have never really put faith in that. But I have driven about ten miles with that light on.
Just to chime in.. 2001 Camaro. At a little above E, when the CHECK GAGES light comes on.. I've refilled and basically it comes out to me still having 2-3 gallons left (can only get like 14 gallons in). I've gone a bit below E a few times, and never run out of gas. I drove to work this morning completely on E, with lots of traffic. About 17 or 18 miles away. For a complete refill, the needle goes past Full. I guess I've got one of those pesimistic gauges
![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
3.5 divided by 16.8 = .208, or about a fifth of a tank. I'd think you would still be ok.
But, I still don't let mine go down that far, mostly because I like it filled and ready cruise with out worrying about gassing up.
ever do a search on what it takes to change the fuel pump in an Fbody? you have to cut a hole through the sheet metal inside your trunk. and this is the faster, easier method.
Well my gas guage doesn't work and hasn't since i've owned my car and i've ran my car completely out of gas i believe 4 times and i have had not one problem out of my pump
Personally i think that the dont let your car get low on gas or your pump will go out is just complete Bull ****... Thats just me though and my opinion...
All my car needs is fuel sending unit but i have just never bought one..
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Not in my car. I take it to the E or close to it every time. When it is exactly on E I have 2 gallons left in my tank.
the only time my gauge even gets near completely full is if there is gas overflowing out of the tank when im trying to pump. I "try" to fill up at around an 1/8 so i can get the most accurate mileage reading
