General LSX Automobile Discussion Non-technical LSX related topics.
Blew my tranny last night :(
Old 10-07-2007, 06:06 PM
aaron653's Avatar
op...you should have just left out the part about you drinking....are you retarded?
Old 10-07-2007, 10:40 PM
Tuffguy610's Avatar
Not to highjack this thread, but isn't doing anything over 100 in an automatic bad for the car when your making the tach scream near redline? I was toyin around with my friend's Cobra one night, and saw my tach scream to 6200 at one point, and then I remembered that transmissions are about 2 grand to fix. I don't think I'll be doing that too much more.
Old 10-07-2007, 11:05 PM
CAMAROZ28SS's Avatar
that sucks man
Old 10-07-2007, 11:23 PM
B4CZR2's Avatar
Originally Posted by ShortChevy
x2 been there...
x3 Probably fried the clutchs or bands or both. not really an expert on 4L60e's but could be easy enough to rebuild yourself if thats the case. then it would only cost maybe 3-400. I rebuilt mine once. if you get a TC get a good one too! You don't want to ***** foot around with that. With a good TC your looking at 6-1000 more. Assuming no damage to the housing the fluid can run out the vent tube or tailshaft. Due to air currents moving all around your car it will always end up all over the back of the car.
To answer that, I have to say NO! Being low on tranny fluid probably caused your situation or being a mustang
Old 10-08-2007, 12:38 AM
88blackgt's Avatar
Last I checked he didn't ask for your opinion on drunk driving and speeding.
well last i checked i didnt care if he asked for it or not.
Old 10-08-2007, 12:44 AM
LS1Silverado05's Avatar
Probably looking at close to $2000 depending on what you have done...and who you know etc etc. I had mine removed,replaced, and fully built for $1200...but I had a good connection for a side job trans tech. If you pull it yourself you will save some grip...but in the end probably wish you just paid to have it removed+replaced. (The top bellhousing to block bolt is a real joy! )
Old 10-10-2007, 09:01 AM
B4CZR2's Avatar
Yeah those are fun to do! But is not too bad. I more or less will be removing my trans this saturday to repleace the Torque Converter. My Buddy and I at his shop did the same job in an hour and half from the time we pulled it in to the time we pulled it out of the garage. But doing it in your garage more like 4
hours lifts are a great thing to be able to use when doing anything with these cars.
Old 10-11-2007, 01:25 PM
6THZ28's Avatar
any stock transmission should be just fine at that rpm. what gears do you have? i have 2.73's so i crawl outta the hole but i dominate top end.. i have exceeded 150 several, several times without incident. decided to go for it all last weekend and here i am now with a busted something or other.. won't know till i open it all up
Old 10-11-2007, 01:39 PM
6THZ28's Avatar
I've been called worse by better, man..
Old 10-12-2007, 02:35 AM
psykoTA's Avatar
If its toast, swap in a 6 speed. Thats the only thing I regret about my car, the A4.
Old 10-12-2007, 02:40 AM
cryptnosis's Avatar
Same here as well. I have went through 2 trannys in last 6 months and in hawaii it is hard to find performance, i bought the stage 2 as well.. cant wait till it gets here.
Old 10-12-2007, 10:27 AM
  #32
dragonrage's Avatar
Well, he did go 165 after going drinking.
