Can you jump a tuned car with jumper cables?
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
I jumped mine 4 years ago--before I got my Optima.....jumped at least 6 times from my friends 57' Nomad...no big deal at all...used the battery ground all times......worrys= overated I think...........
Like already said the whole reason why you should use a ground on the car opposed to the one on the terminal is IF there is a spark THERE IS A SMALL POSSIBILITY that there could be fumes from the batery that can go BOOM and blow the battery. Like already stated you may have a better chance of gettin struck with lightning but why take the risk if you dont have to
the reason you avoid using the battery is to a) avoid spark in a potential fire situation from igniting gases from a leaky battery. (0.0000001% chance)
b) there's less resistance if directly attached to chassis or engine (negative connection)
c) GM puts a positive lead for you to use in jump situations as well which is closer to the alternator...
