LS1 guy, what are my options for intake manifold.
Is the LS6 and fast 90 my only options when it comes to the intake manifold. I want the best bang for the buck. I'm guessing that's the LS6. The only thing I've done to my car is change the oil and put new coolant in it. Can I change this myself? I'm a real noob!
i'll be doing cam swap, probably go with the torquer 2, so i was told to swap out this intake manifold. I found the writeup on ls1howto.com
So these parts aren't interchangeable or what? Where do I find them?
"Parts you will need:
- 1x 2001+ front coolant pipe - #12568478
- 2x 2001+ rear coolant plugs - #12562788 (Note, you can use a 2nd coolant pipe in place of these plugs if necessary)"
bbk, victor jr, weiand, typhoon, slp ls6, gm ls6, and i swear there is another one....a ls6 intake is not a "complete" bolt on, you will have to swap coolant pipes or grind down the ribs on the bottom of the ls6 manifold..you may also want to pick up a oil sender at the back of the intake because you may/may not break it, it is a coin flip
...you can find those coolant pipes at thunderracing.com, ws6store.com, speedinc.com and im sure a few other sponsers carry them
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
it really isn't that hard, if you have a friend that knows a lil bit of what he is doing you can do it...the only part that was tedious was the lining up and grinding down of the ribs....i used brake grease and applied it to the coolant hoses..then i laid down my intake and i saw appox where i needed to grind down...there are a few how-to's on here and one good one is on ls1howto.com
Man, I wish I lived near you................I love tearing into someone else's car!!
Good luck
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
I actually posted this idea up already. I want to do a cam, stall and some other goodies. Some guy from Texas was the only one that offered to help. I'm probably gonna do it too, cuz i hardly see and f-bod, let alone someone that knows anything about them. All I have to do is drive down there and probably give him a few hundred cash for him to do it. Then drive to texas speed to tune it. I know it's easy to you guys now once you've done it, but I was scared to do my fuel filter. I printed out everything on howto and then I got it no problem. Same with my coolant. I was pretty scared on that one...no prob now.
'Bird Director
You'll need these if you go the FAST intake for sure. The part numbers listed are GM part numbers, so you can either order them online from a GM parts dealer or visit your local dealership. Scoggin-Dickey (a site sponsor) should be able to help you out----------------------->
I just installed my LS6 not a couple of months ago. It is a piece of cake but watch your knuckles. I banged mine up pretty back swapping the damn thing. I think the only reason to get a FAST is to get all available power possible. I don't think a couple hundred including the price of the 90mm TB on top of it is worth the gain if it's still a street car.
