How do I chose which heads?
I have an 02 SS. It has a .585 lift comp cam. If that's enough info, does anyone have suggestions as to what heads would be best? What other info do I need to know before I chose heads? I've been very confused on this for some time now so the more info I get the better. Advanced thanks!!
how much are u will/can afford. what are ur other mods/plans.. too many things to consider here then just lift. unless u r planning to stay with that cam and not go bigger then it makes things a little easier. heads around 2.02/2.05 in valves, 1.60/1.57 ex valves with .600/.650 rated valve springs. u got several sponsors here that sell heads and by talking to them u can get better advice and price in ur budget......
Money's not an issue, this is my dream car so i'm not too worried about what it'll cost me. The entire suspension is upgraded, Torque arm, LCA's, SFC's, STB, Shocks, springs.I have the k&n cold air intake, SLP longtubes, 3 in. borla exhaust, drilled/slotted rotors w/hawk pads, progressive lowering springs, 6 point cage. So basically I think I just need to figure out which heads I want to go with and a new clutch. I know the cam is comp cam .585 224/224, .114 lsa. I don't have the cam card in my possession right now (i'm currently in Iraq on contract) so that's about all the info i've got.
I have a head Q also....
As far as AFR's go, with the 205, 215, and 225 head, the bigger the numbers the bigger the cubes? eg: 205 is more for a 346, 215 is for a 383 and 225 for 402+?? im just guessing.
Also how do you choose what size combustion chamber?.. 59cc 64cc blahh.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Combustion chamber size (along with piston volume) determine compression ratio. The larger the combustion chamber, the lower the compression ratio and vice versa.
