Police Inerceptor Camaros
#81
i friend of mine had a 94 Z28, and said he put in the B4C LT1 cam and reflashed him PCM with a B4C program and the car screamed? He worked at GM dealer and was the only guyt hat worked on the Local B4C cars when they came into the shop. I thought the LT1 cars did have a different cam and tune in the PCM, but the LS1 cars were just a debadged Z28.
I'm almost convinced that working at a dealer guarantees you know LESS about your cars than anyone else.
#82
SOOO very true! I think the dealerships/dealer mechanics make up 90% of the BS that gets spread around about different cars and trucks....
#83
#85
now dont go jumping all over me here, but i read that cop cars had a shatter resistant glass in the doors (and i would assume hatch/rear window) do any of your f bodys have that?
and its not a rumour, i did a google the other night to find something to post on here about the fact that B4C cars were not 'super optioned' and i found a site that was an internet newsletter for the government vehicles. they posted about the options that you could get from the factories for law enforcement and the handling, and performance. basically its like a motortrend article comparing the stopping distances, top speed, and handling of pursuit cars. the oldest archive was fall of 2002 so the F body was already cancelled for comparison, but they did mention it.
#86
#87
18th paragraph down, and i dont know what your problem is. i was asking a ******* question.
http://www.policeandsecuritynews.com...tation2003.htm
theres a wealth of information on the net, along with bullshit like the stuff in this thread. maybe if you took the time to read what i wrote, and then got curious enough to actually check, you may see what i am talking about here....
#88
Jeremy
#90
So many people don't read this thread that it should be a sticky so that even more people will ignore what information is already there
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
#92
From: Central Indiana Honors: 4th grade spelling bee contestant
#93
ok guys, i know that you are all probably tired of the question. but flipping on everyone that asks one is probably not the way to do it.
if your that tired, why even bother reading this thread? just bypass it and let us 'retarded' guys keep going. there does seem to be a few guys in here that are as fed up enough to actually answer the questions without insults and degrading 'moron mentality' comments.
its been the same since words were invented, if you dont know for sure, ask someone that does.
if he comes back like you guys are, just assume he is an *******.
i have been asked about my face since 96 and not once have i got rude, because not everyone knows.
chill the **** out, or quit reading. i dont go into threads where i am fed up with peoples comments, you guys should try that. less stressful....
p.s.after reading through the link again, they were making the shatter resistant glass in 03/04 so if it makes you guys feel better............me learned sotin' frum awl yur halp. duhh huhh huhh huhh
#94
You have 42 posts, and already you're an expert on how everyone should handle threads.
#95
B4C cars ARE special. they are the only Camaro F bodies that are V8s without being Z28s. like i said before, SSs cars are just Z28s. also standard on Auto B4Cs were the 3.23 gear, aluminum drive shaft, power steering cooler, no t tops, body color tops (just like V6s) B4Cs could be ordered anyway you wanted them. they could have leather seats, monsoon, 6 speeds or any of those other options could be ordered by a department, or like most in 2002, by individuals. NO B4C is a Z28, and NO B4C EVER came from the factory with T tops. there was talk of heavy duty wiring, that dosent exist. another thing that i dont understand is the trans cooler thing. ALL the cars just have trans coolers that are in the radiator. they dont have an external trans cooler.
I've heard of them having a higher output alternator, I can not confirm since my car does not have the OEM one. My car also has the foam-rubber steering wheel instead of the leather Z28 one. The lower control arms are supposedly 1LE pieces with the stiffer rubber bushings in them. I think the B4Cs were also limited to the 3.23 gears in the automatic cars. The 2.73 ratio was not available. Mine had a block heater also. Not sure if that was an option or not.
#96
Block heater here too.....and the standard alternator on its way out. Pretty sure they didn't do anything special for that.
Block heaters usually dependent on where the car came from. Mine's a ex colorado.
I don't have another car to compare lower control arms so no clue on that. They also ALL came with z rated tires. duh on that though.
#97
I don't remember there being a POLICE PACKAGE offered, but. What might it have different:
Suspension - perhaps worthless and worn out with all the hard miles. I sure as hell would look at this car on a lift.
Interior -
Electrical - high capacity - These things have pc - dash cams - radios - phones - etc..
Brakes - might be larger - or vented
Fuel Tank - might be larger
Tires - a very high speed rating..
I would ask to see the title. See if anything is mentioned. I would also ask for a carfax. it will identify who owned it..
Someone isn't saying this for extra value are they?
An old man and his dog - Jake
Interior -
