will this catch can work ok?
I know some cans work better than others. Does anyone recognize this universal can and whether or not it will work satisfactorily? Is it worth buying for $40 or should I just buy a reputable one? Thanks for any input http://img.photobucket.com/albums/v3...Picture004.jpg
well ok, a catch can is a catch can no matter which one u get, sure there are catch cans with baffles in them but those cant stop moisture in the air or even the oily mist in the air! if you really want good insurance on oil not getting into the intake you need more then just a catch can! the re are some people that run 2 husky oil to water separators after the catch can, just to be safe!
lol vatozone!! hahah well the mod that i did is the complete SMH pcv mod hold on i think i have a link! everything i got was from vatozone the ones i used are fuel filters, and i put my pcv valve AFTER the catch can! then after the pcv valve are the 2 filters inline then to the intake
here is the link http://bowlingss.com/LS1_How_To.htm then click on SMH pcv mod
well it dident take me too long, like i dont know an hour or so since i had to run to the store twice because i forgot to buy a few fittings, but as you can see i replaced the drip can they use with my catch can! you can do the same since i guess you already have a catch can!
and if you have an 01 or 02 it will be easier because the damm egr wont be in the way! and yea i love that site it has everything! and all the links work!! lol
i had it installed for lik 1,000 miles, my filters collect some oil mist but my catch can recently had a bunch of nasty *** condensation, it was a milky oily color! i recommend you do this mod man! you will see the oil that gets cought in the canand in the filters! i usally clean the filters with some carb cleaner when ever it gets dirty
ONE catch can is fine, you do not need to obstruct with anything else. If your one catch can can't catch it all try another brand. My AMW catch can on both of my cars works great. Zero oil gets past them.
If that $40 does not work then sell it on eBay. Then get a better one if need be.
Peace,
Craig.
Peace,
Craig.
That pic of the catch can is useless, how about a pic of whats inside of it, not a top view of the fittings. Love the pre-kinked rubber hose.
You need two catch cans on these cars, one in the pcv line and one in the breather line. The breather line is the one between the tb and pass valve cover.
Peace,
Craig.
Peace,
Craig.
Yea one per line.
Do a search.
Run your car semi hard and look in FRONT of the TB blade. Some cars will get a puddle of oil in the bellow and it comes from the breather hose.
Crankcase vapor gets sucked into the intake through the pcv valve connection when theres high manifold vacuum.
Crankcase vapor also gets sucked(or blown) into the TB from the passenger side valve cover through the breather hose during low manifold vacuum.
People who know use the dual catch can set up. One for each line, not two for one line.
Do a search.
