General LSX Automobile Discussion Non-technical LSX related topics.
went to the track. need advice!
Old 03-25-2008, 06:52 PM
hawaiianpunch01SS's Avatar
also i did not mention that track conditions were near perfect as well as the weather. but it still seams that their must be something done to this car! we are going to see if we can track down the old owners and see what may be done. but i am still wondering what a bone stock cars time is?
Old 03-25-2008, 06:54 PM
04cobra13's Avatar
1.69 60ft on street tires.....i doubt it..
Old 03-25-2008, 07:00 PM
says the mustang driver! lol ill post the time slip up tonight!
2nd gear launch from 4k on nitto NT555s runing low pressure. its a quick time but it happened.
Old 03-25-2008, 10:08 PM
dshag's Avatar
i bet diff gears and then i believe it the rest can be stockish
Old 03-25-2008, 10:43 PM
WhosNXT's Avatar
^ Yep, thats what I said in my previous post. I think I nailed it down pretty closely. He had Nitos, P&P TB, cat-back, lid for sure...add on gears, ud, tune, maybe aftermarket clutch and its very possible.
Old 03-25-2008, 10:45 PM
SladeX's Avatar
it's not stock, that's for sure, not many 10 bolts can pull a 1.6x 60 ft on drag radials and live to tell the tale, let alone from 2nd gear...
Old 03-25-2008, 10:59 PM
WhosNXT's Avatar
I believe the "ten bolt will explode not matter what" is getting a little out of hand lately. Yes the ten bolt is weak, that is a fact. It is no match for a 12 bolt or 9 in. On the other hand the ten bolts last longer than many people give them credit for. I have seen countless members on this forum with h/c cars in the mid 4s and high 5s hp range on stock ten bolts for thousands of miles. There are some FI guys with over 5 up to 6 on the stock ten bolt. The OP's car is not a race car that is taken to the track every weekend. They just bought it and wanted to see what it would run. If this car had the mods I mentioned in my previous post along with what the op confirmed it had, this is not impossible. The ten bolt will make it down the track a decent amount of times before letting go.
I had my factory 10 bolt for 30k miles in my T/A after the H/C swap, no issues.
Old 03-25-2008, 11:05 PM
SladeX's Avatar
those of us that rag on the ten bolt speak from experience, ie boom
the ones that hold for sub 2.0 60 ft times with a m6 are FEW and far between and I'd like to see them last more than 1 pass with slicks. If lucky 2-3 and gear howl...
Old 03-26-2008, 12:50 AM
miamifan3413's Avatar
Launching from 2nd would be easier on the rear and harder on the clutch btw
Old 03-26-2008, 12:55 AM
I agree.... some hold up and some don't. I blew mine up with 4.30's which was tooooo much gear. The pinion gear was just too small and the ring gears too thin to handle the torque of the pinion gear. Ate most of the teeth off ring gear then the pinion shaft broke off. It was a mess to say the least When I had the 3.42's in, I beat the living dog **** out of the rear and it held up just fine....DR's and all, I never did a high rpm dump though cause i know better.
Old 03-26-2008, 01:05 AM
ae13291's Avatar
can i do a 2nd gear launch with my stock 3.42? or will i toast my stock clutch? or will my car bogg down?
Old 03-26-2008, 01:19 AM
  #32
ErikElvis's Avatar
I wouldnt do it.
Old 03-26-2008, 01:23 AM
  #33
ae13291's Avatar
Originally Posted by ErikElvis
I wouldnt do it.
maybe if i get 3.73 then, but im still not sure with my 3.42's i think the stock clutch will toast! but im amazed at the op that he ran a 1.6 60" with 2nd gear launch!
Old 03-26-2008, 12:53 PM
  #34
I have 3.90's and a ls7 clutch which has been very durable for me.....if I launched in first I would always spin pretty bad of the line. Launching in second has worked for me pretty good so far until i get a better rear and dr's I wouldn't do it with stock clutch and gears...it WILL toast your clutch for sure
Old 03-26-2008, 01:52 PM
  #35
02 Camaro SS's Avatar
Nothing about those numbers makes sense. With that 60' and that trap it should have put up a better time but, as stated, the most impossible part is the mph. No way it's that close to stock. Not a bad thing but it has to have a little more work done to it to pull that trap. Maybe it has a quiet cam.
