No brights?
No brights?
So am I missing something, or does my T/A not have high beams? My friend also says he hasn't found them on his 2000 camaro.
My High Beams dont work either. Kind up pisses me off but I dont drive a lot at night. Just thinking getting HIDs.
EDIT: I was told if you have your Fog Lamps on the High Beams wont work.
It seemed like pieces were going to snap when I pulled it... I sprayed some lubricant on the appropriate places in there though, and now it works. Still a bit stiff though. Thanks.
When I bought my Z28 it didn't have brights.
That's because the car was a cop car in its previous life. Apparently the police like to use that switch for something like all the strobe lights. All I had to do was reconnect the wires, though.
Ok, now you lost me again. You're head light doors on a TA are CLOSED unless you turn the lights on. So even if you could flash you brights without turning on the lights, you would be flashing them at the radiator.
open the lights and flash when you pulled it toward you.
