Sponsored by: CARiD
Wheel bearing?
Old Nov 3, 2008 | 08:29 PM
2000Z28ls1's Avatar
Default Wheel bearing?
I tried a search, couldnt find much on wheel bearings, Maybe I searched wrong. Anyway what is the best way to diagnose that is what it is and which side its on. Also I keep reading that arnt that hard to swap out anyone with some info on the install please chime in.
Thanks Jim
Old Nov 3, 2008 | 09:11 PM
ghardester's Avatar
The wheel bearings are a sealed unit, very easy to change, just 4 bolts and a sensor plug in. But because they are sealed they usually don't go bad often. Unless you have a lot of miles on the car. Many front end grinds and noises that you might think are the bearings are actually brake pads. Be sure it's not brakes before buying a wheel bearing.
Jack up the front of the car. Take off the wheel. Turn the hub by hand. Check the brake pads, inner and outer. And see if you really still think it's the bearing.
Old Nov 3, 2008 | 09:19 PM
2002_Z28_Six_Speed's Avatar
I think you would know if the wheel bearing is bad. They are about 230 from the dealer to replace.
it seems to me that FWD cars have more front bearing failures.
Old Nov 3, 2008 | 10:33 PM
2000Z28ls1's Avatar
Well the car has 113000 miles, my dad drove it back in july said that is what he though it was, the brakes are new, it happends mostly on the highway I get a grind/hum when I change lanes right to left. I think its my front right cause when I changed my brakes out I had a weird tug or drag on the wheel. I need to investigate it more maybe sometime this weekend ill try to take care of it. Thanks for the imput so far guys.
Old Nov 3, 2008 | 10:40 PM
That does sound like a wheel bearing!!
Old Nov 3, 2008 | 10:56 PM
2000Z28ls1's Avatar
Im gonna check it out I might have some time on wednesday. thanks for the imput guys!
Old Nov 4, 2008 | 12:03 AM
have a hammer and chisel on hand to help tap out the hub.
i usually tap in a small screwdriver and then move up to the chisel. i am talking about minimal effort taps. no bangs.
the bearing might not feel odd when you turn it and could still be garbage. ud have to replace to know.
Old Nov 4, 2008 | 02:53 PM
2000Z28ls1's Avatar
Sweet thanks I dont have a chisel but Im sure a flat head will work.
Old Nov 4, 2008 | 03:12 PM
2000Z28ls1's Avatar
Any brand to watch out for, or are most the same? I talked to my local advanced auto they had a national, for 159 or a ?NG????something or other for 103.99 my autozone here has a ?Dimking? I want to say?
Old Nov 4, 2008 | 03:16 PM
2000Z28ls1's Avatar
The AC delco this once place had was $250+!!
Old Nov 4, 2008 | 07:10 PM
_JB_'s Avatar
Put a screwdriver to your ear and the hub; spin the hub and listen for a noise. I paid ~$100 for the hub assembly at Advance Auto or something like that.
Old Nov 4, 2008 | 07:36 PM
2000Z28ls1's Avatar
I bought a Timken one from autozone got it for like 140 with tax. gonna mess with that tomarrow.
Old Nov 4, 2008 | 08:00 PM
Blackhawk777's Avatar
I'm having a similar problem myself. It kindof sounds like a grating noise when it's coasting at low speeds, and it's not rotors or brakes, both are new. the wheels also only spin about 1 1/2 to maybe 2 times when the tires are in the air. shouldn't it go more than that?
Old Nov 4, 2008 | 08:16 PM
hard to tell with disc brakes installed. the pads will always have some friction!
Old Nov 4, 2008 | 08:18 PM
That is true, but even with EVERYTHING off, it still only turns 2-3 times freely. I've heard it should almost 7 or 8 times.
Old Nov 4, 2008 | 11:37 PM
Even a brand new one won't free spin. They are kind of hard to turn with 0 weight on them. Shouldn't just spin around.
If you have having a humming or grinding sound that could be a wheel bearing. Bearings in these cars are going to wear more frequently because of how we drive them.
rotating speed and cornering kills bearings!
The only difference I could tell between a whirling wheel bearing on a 2003 Impala was that the old one was slightly harder to turn. Installed the new one and the sound went away and the car stopped pulling.
Old Nov 5, 2008 | 12:04 AM
SladeX's Avatar
I think my wheel bearing is going on the driver's side rear, during cornering I can "hear" a grind noise from the rear, straight at speed isn't a problem, but it becomes more pronounced when I am turning. Also, stepping on the brakes doesn't change the sound or get rid of it leading me away from thinking the brakes are done.
Old Nov 5, 2008 | 01:20 AM
Formula Freak's Avatar
I have birds chirping in my rear wheels when cruising.Would lightly applying the brakes,making the chirping go away,be a wheel bearing issue? I have noticed some new grooves on the middle of my rear brake rotors...they are a little discolored from the rest of the rotor also.Pads still have meat on them...
Old Nov 5, 2008 | 10:02 AM
no its the brakes for sure
Old Nov 5, 2008 | 12:00 PM
2000Z28ls1's Avatar
I swapped mine outtoday, thanks fo the help went pretty smooth, seems to have fixed most of my complaints, I havnt taken her over 60 mph but around town it seems my steering is tighter.
