Change oil soon signal HELP
I have a 2000 camaro I just changed the oil 200 miles ago and used mobile 1 synthetic oil and a bosch oil filter the car was running fine until when i was driving on the free way and my change oil signal came on and after 5 min it turns off now everytime i start the car that light stays on for 5 min then dissapears someone help me out ASAP
Are you the first owner of the car. Have you had it long? Light comes on every 6-7,000 miles. Next time you get in the car turn ignition on but don't crack it and at the same time press brake pedal for about 15 seconds-20 seconds. Then turn ignition off. Start the car and it should reset.
Actually, I think it depends on the car. For 1998-2002 LS1 F-bodies, you press the "TRIP/OIL RESET" button (right next to your odometer) and hold it until the light goes off. Your key must be in the "Accessory" setting (Right before the "RUN" setting). Light shouldn't appear for another couple thousand miles.
My '02 and '01 both reset by turning the key to on (not back into accessory) then immediately pressing and holding the trip reset button, and wait for approx 15 secs, turn igntion off, and just start the car up, it will turn off like normal.
There are two ways to reset it.
Turn the key to run, engine off and hold the trip reset until the change oil light flashes.
Or turn the key on engine off and pump gas pedal about five times.
The light comes on depending on many things, not just mileage.
well i have to wait till tomarrow to try all these out because i just took it to my mechanic because my gas gauge does not work inside my car so i got a new reader and now pulling out the exhaust fuel pump and gas tank i hope to get it back soon
i honestly dont even know lool all my car has been doing is triggering sensors and all i need is another one to turn on so far the only sensor that stays on permanently is my airbag sensor and hopefully going to get that fixed as well soon
