Sponsored by: CARiD
Knocking at very high rpm?!
Old Dec 3, 2008 | 07:20 PM
djsanchez2's Avatar
Default Knocking at very high rpm?!
Ok fellas, i'm having trouble tracking down a high rpm knock. I changed the plugs, wires, fuel filter, cleaned injectors, fuel system, MAF, and AIT sensors.
It wasn't doing it for a while and it seems like the cold weather brought a knock with it. What do you think it could be other than that lame diagnosis?
Old Dec 3, 2008 | 07:57 PM
nemss1's Avatar
probably detonation/ping
Old Dec 3, 2008 | 08:32 PM
Formula413's Avatar
Yup, that's what knock is all right...
Two quick thoughts:
Vacuum leak?
Any oil consumption?
I'm assuming you run premium of course. Got a fuel pressure tester?
Old Dec 3, 2008 | 10:47 PM
ghardester's Avatar
[QUOTE=Formula413;10595234]I'm assuming you run premium of course. /QUOTE]
That's right. If you are using regular or plus look no further for your problem until you run a few tanks of premium through it. And then always use the highest octane gas available to you.
Old Dec 3, 2008 | 11:16 PM
djsanchez2's Avatar
Always run 76 brand 91 octane. Not sure if a i have a vaccum leak, i tried checking all the lines even spraying them w/ brake clean to see if the idle fluttered. Got nothing out of that. No abnormal oil consumption. My old Z used to eat oil like a fat chick with a 1gl. bucket of Haggen Daz though so i know the signs of that one.
I'll try the fuel pressure tester. Think my fuel pump might be going out? It does have over 100K on it.....
Old Dec 4, 2008 | 11:17 AM
nemss1's Avatar
bad A/F ratio can also cause knock
Old Dec 5, 2008 | 10:37 PM
jrinehart81's Avatar
thats the way mine started ended up having 4 spun rod bearings and two cracked rods,only had 59,000 miles
Old Dec 5, 2008 | 11:14 PM
wrencher's Avatar
wrencher
If you suspect it of pinging, how is the fuel pressure/volume?
Sure it's not the motor internally?
I see your in cali, on the far side could also be a busted cat, since you have to run them there.... Seen that mimic the noise of spark knock before.
Old Dec 6, 2008 | 12:49 AM
djsanchez2's Avatar
I am not going off the sound alone, i am able to see it on the scanner. It peaks and holds about 3.5-3.8 knock retard
Old Dec 31, 2008 | 05:59 PM
djsanchez2's Avatar
Figured it out, checked the spark plugs again and it stopped. Guess i got a bad batch.
