Sponsored by: CARiD
Window Problem
Old Dec 12, 2008 | 12:22 PM
ReApEr75's Avatar
Default Window Problem
I started my car this morning and when i went to push the button for my driver window to go down it only goes down about half an inch then stops. Then when i go to put it up, it doesn't move. Then about 1 minute later i push the button again to put it up and it goes up. I did this a few times but it does the same thing. Is it the Fuse? Window Motor? Button? Can anyone help me. Thanks i appreciate it.
Old Dec 12, 2008 | 12:34 PM
2001NBMZ28's Avatar
Usually when they start failing it does the few inches/stop/inches again/stop when putting it up. I'd replace the motor before it completely fails in the down position.
Old Dec 12, 2008 | 01:18 PM
ReApEr75's Avatar
Thank you for the help!
Old Dec 12, 2008 | 04:38 PM
wht01ws6ta's Avatar
Get a replacement motor, it's a pretty easy fix.
The link for the Camaro window replacement has pics and I used that one.
Replacing Power Window Motors
https://ls1tech.com/forums/2977771-post18.html
Old Dec 12, 2008 | 06:34 PM
SOMbitch's Avatar
To me it was a COMPLETE PIA and it took another person just to hold it up.
Now the damn DS is going
Edit: And use rivets, much easier than F'ng with bolts IMO
Old Dec 12, 2008 | 07:52 PM
wht01ws6ta's Avatar
Funny you mentioned the bolt cuz I snapped one of the small ones that came with the motor and ended up drilling out the holes and putting a big *** bolt in there cuz that was all I could find at the time lol.
You can do it by yourself, just use a 2x4 or something to hold the window up.
I hate changing spark plugs but I thought this was easy, dunno.
Old Dec 13, 2008 | 02:33 AM
ReApEr75's Avatar
Ok thanks!
Old Dec 13, 2008 | 02:37 AM
Counted Out's Avatar
It's the motor. Exact same thing happened to mine.
http://shbox.com/page/windowmotor.html
You won't find a better guide than that, IMO.
Old Dec 18, 2008 | 04:31 PM
pwilson357's Avatar
Cool 99 Camaro Z-28 window motors BAD..
I had dealer replace driver window motor 4 times in 2 years. they are junk. Mine always end up 1-2 inches from top and stop! The brushes in these are trash. I disected 2 motors!! they start off intermittant, and fail forever in 1-5 more uses as the carbon/graphite brushes wear/burn away or jam in their slides. Motors are about $55. And wear gloves...that fiberglass door itches!! might be a good time to replace the door speaker...they go every 3 years or so, and are 2 Ohm ones!! be careful of what you put back in the speaker/ window motor removal hole. wrong speaker will sound bad! this link is invaluable to see how to do the work...
PS. might check on the 2 felt covered restrainer "arms" that hold tension from the inside of the glass to push it against the outer window wipe. These break easily, allowing a sloppy window, and the probability that the glass may get scratched from the inside. these 2 are mounted inside at the top of the door w/ a slot adjustable bolt. make sure your's aren't broken from slamming the door too often. they are $12.00 ea. from GM. and worth it for a tight seal. see above link to see these. on the upper inside of door at the top.
Last edited by pwilson357; Jan 6, 2009 at 01:39 AM. Reason: more help with window how-to-replace-it
