Sponsored by: CARiD
simple question
Old Dec 31, 2008 | 11:49 AM
blackodium's Avatar
Default simple question
can anyone tell me what this is and why after an oil change i have an oil leak.
Attached Thumbnails simple question-image0013.jpg   simple question-image0012.jpg   simple question-image0014.jpg   simple question-image0015.jpg
Old Dec 31, 2008 | 11:55 AM
NBM-LS1's Avatar
The thing in the second picture is the starter. It should not be leaking oil as there is no oil that goes to that. The first picture is of the bell housing.
Those little metal plug/covers can be taken out so you can look up in there and further investigate.
Did you or someone else change the oil?
Old Dec 31, 2008 | 11:56 AM
blackodium's Avatar
i changed the oil. it was pennzoil 10w-30 full synthetic and a k&n oil filter.
Old Dec 31, 2008 | 12:03 PM
sgm98ws6's Avatar
Does it continually leak or was it just after you changed the oil. It might just be frame drippage. I havent seen under an ls1 but it could be that you spilt some oil putting in the engine or when you removed the filter it splashed some on the block and now its running down.
blackodium's Avatar
i went to investigate the cover on the bell housing and nothing but dust and dirt. no oil in there. it has to be running from up top. but dont know where
Old Dec 31, 2008 | 12:05 PM
blackodium's Avatar
well it seems to be alot. alot more than i might have spilt. the funny thing is the oil level seems level/full without adding since change which was 1500+ miles ago
Old Dec 31, 2008 | 12:07 PM
sgm98ws6's Avatar
Could be valve cover gaskets leaking a little. I dont know if ls1's do it but ive seen some oil caps on older chevys leak a little.
Old Dec 31, 2008 | 12:10 PM
blackodium's Avatar
i actually thought that to. but of course it would not be that simple
Old Dec 31, 2008 | 12:12 PM
sgm98ws6's Avatar
can you see it leaking from anywhere up top
Old Dec 31, 2008 | 12:13 PM
NBM-LS1's Avatar
There are a few things up top that will allow oil to leak. Check around the covers and the pcv hose in the back on the driver side valve cover.
Old Dec 31, 2008 | 12:14 PM
blackodium's Avatar
ok ill check but keep it coming
Old Dec 31, 2008 | 12:19 PM
sgm98ws6's Avatar
well if its the back of the pan by the bell housing where it is leaking it could be a rear main seal but i havent been around ls1's really at all.
Old Dec 31, 2008 | 12:28 PM
blackodium's Avatar
i dreaded hearing that. i thought that the first time i seen the oil. but it has 67,xxx miles.....
Old Dec 31, 2008 | 12:43 PM
sgm98ws6's Avatar
well i hope that isnt the problem.
Old Dec 31, 2008 | 12:51 PM
blackodium's Avatar
by the way awesome car!
Old Dec 31, 2008 | 12:53 PM
01ssreda4's Avatar
leaks always go back and down from gravity and wind. look for the most forward and highest point that is wet with oil and there is your leak. if confused wipe everything dry and drive it awhile and look again.
Old Dec 31, 2008 | 01:03 PM
blackodium's Avatar
I have wiped it down on the bottom but they reappear. as far as the top goes nothing in sight
Old Dec 31, 2008 | 06:54 PM
01ssreda4's Avatar
look from the bottom and find the furthest point forward that is wet with oil. then look for the highest seal or gasket thats wet from that point. there is your leak. dont look at the frame or anything else. look at the motor.
Old Dec 31, 2008 | 07:01 PM
blackodium's Avatar
ok we will see what we can find
Old Jan 1, 2009 | 01:47 AM
Formula413's Avatar
If it's not missing a noticeable amount of oil after 1500 miles I wouldn't worry about it. It's probably just crank seal seepage. Were you running synthetic before? Sometimes switching to synthetic will reveal leaks that were not noticeable before.
