Sponsored by: CARiD
Windows rattle when 90% up
Old Dec 31, 2008 | 07:50 PM
KalTorak's Avatar
Question Windows rattle when 90% up
I'm seeing lots of threads describing burnt-out window motors and such; I'm not all the way there. I'm guessing there's SOMETHING broken in the door or on the window itself, but I'd like to have a clue what to look for before I even consider taking the door apart.
I've seen a couple threads with pictures of the door completely taken apart, but what I haven't found is a good description of what the whole mechanism's supposed to look like / work, nor any sort of step-by-step disassembly guide.
Does that exist somewhere? Have I just missed it?
What holds the window in place when it's mostly-up but not yet supported by the rubber gasket on the T-top panel?
Old Dec 31, 2008 | 08:05 PM
Tally TransAm's Avatar
if you take the door panel off on the top of the door there are 3 or 4 guides for the window that you can adjust, if the window rattles when it is not all the way up you probably just need to snug them up
Old Jan 1, 2009 | 12:21 AM
98boxer's Avatar
My driver side rattles and i have those top pins tight against the windows, don't know the window rattles.
Old Jan 2, 2009 | 12:53 PM
RCowan's Avatar
Read this:
http://shbox.com/1/adj_window.html
Old Jan 2, 2009 | 05:15 PM
wrencher's Avatar
wrencher
Originally Posted by RCowan
that is good info also if the regulator itself is loose it will just rattle no matter what. You'll have to replace it to cure the problem.
Old Jan 2, 2009 | 08:30 PM
KalTorak's Avatar
Thanks, guys.
The shop I took it to suggested that my "guide pins" had "worn down", and that fixing the problem would require all sorts of dependent parts to be replaced.
98Boxer also mentions "pins" in his (her?) post.
The window picture at shbox.com shows guides that don't look at all like pins to me... but it's also the previous generation F-body.
Finally, what/where's the "regulator"?
Old Jan 2, 2009 | 08:34 PM
slvr98camaro's Avatar
i have crank windows and it does the same thing, i usually just roll them down a bit till it stops
Old Jan 3, 2009 | 08:57 AM
Viper's Avatar
http://www.geocities.com/andrew111_98/
Look in the 'tricks and tips' section of his website on the left, it shows adjusting the window with pics
Old Nov 22, 2010 | 05:42 PM
leadfoot4's Avatar
I wanted to resurrect an old topic....
My windows are beginning to rattle when partially up, however it's not the window stabilizers. I took off the interior panel to see if I could see anything loose, and it appears that the "pins", "bolts", "studs", "bushings", or whatever you call the parts that hold the window to the regulator, and guide it in the tracks on the regulator assembly, have worn and are now "loose".
Does anybody know if these individual parts are available?
Thanks in advance!
