K&N air filter how do you clean
How do you go about effectively cleaning these filters. I had a nice spectre, but it some how fell off. My in-law found one of these laying around, but its needs cleaned good. What kind of stuff do you use to clean them, soap water? its got some deep gunk on it, brake cleaner starting fluid? I'm down on money thats why im asking
Nope, no other way. Hit your local parts house and pick up a kit for $10-20. I buy it by bulk, it's waaaaayyyy cheaper for a 1 gallon jug of oil/cleaner than it is to buy the kits all the time. The kits are easier, though, with the aerosal can of oil/kleaner...
Gasoline, brake kleen, etc will all make it worse, or worse yet destroy the filter.
You can take a garden hose and run water from the inside out to loosen up the bad stuff. But, doing that can also remove the oil you need to trap dirt later.
I have used K&N never had a problem. So it is up to you. Fram is good too.
Anyways when you buy the recharge kit it comes with instructions. Also when i re-oil my filter, after i am done oiling it i do not put it back in the car. I let the filter sit 24 hours before i re-install. But that is me
I use Grease lighting, or Mean Green de greasers and spary the hell out of them till it is complety covered. Then rince with water. Repeat if nessacary. THe air dry in sun or blow dry it with compressed air. Should be white after thatthose process are done. After dry install it, or spray with K&N oil. Either way works.
I'm still using the same K&N since early 2001 with no problems even with FRA/FTRA. If you decide to clean it get their kit, follow the directions and don't over oil it. Or just use the Fram.
Instructions tell you sling off the water and let it air dry.
1 Post
For flat filters I used to lay it on a towel overnight. The water would wick out into the towel and it would dry more quickly. Drying correctly is an overnight deal.
But paper filters are good and they're cheap. I don't use K&N any more. The bling factor is way over for me.
