Ran out of gas WTF???
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
ok well my gas gauge has been out of sync for awhile but I always new how many miles the gas on my car would last me. I always fill up the tank and reset the trip distance. I know that I get about 300miles on a full tank so I usually fill up at 270miles most would be 290miles. But today I ran out of gas at 230miles..WTF??? I did the same procedure of reseting my trip and I ran out of gas. Funny thing was that when i filled up my car filled up with like 16gallons and I thought the car had a 15 gallon tank. I just installed a cut out, and now my car kind feels like it might turn off when im at a stop..the car vibrates a lot and sounds like if the car is choking kinda like if I had a cam. I descreened the MAF but i don't think that's the problem...any ideas what it might be? should I be worried?...sorry for the long post..
thnx
thnx
Well you may have leadfoot syndrome, but I'd be more concerned about the idling issue you have. And FYI be prepared to get flamed for descreening your MAF. And your problem may potentially be there. Are there any codes being thrown? As The Merv said a misfire may be the problem as well. Many people have fouled plugs by fiddling with their MAFs. Swap MAFs with a buddy and see if it resolves the problem, or get some electrincs cleaner @ auto zone and clean your MAF. I for one would pull the plugs and see if the problem lies there. Hope you get it lined out.
A4 cars do not descreend MAFs. M6 cars like it for some reason. You might want to change your fuel filter?
Also i preach this to EVERYONE. Never let your tanke get below 1/4. This will kill your fuel pump if you do that. The fuel is desgined to keep the fuel pump cool, when it get below 1/4 tank, your fuel pump runs hot.
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
you cant run out of gas if you have 14 gallons of gas.. thats just retarded... can your fuel pump take a **** on you? yes..... but you CANT RUN OUT of gas on 14 GALLONS OF GAS!!!!!!
see the irony in that statement?
for realy josh... what about us losers?
