Oil drain plug location?
I've googled like mad, but only 2 guides even have pics, and they look nothing like the bottom of my car :p
I see a bolt on each side of a flat thing on the bottom of the engine that might be it, but what's with the 2 bolts?
You have to drill a 1/2" hole right at the bottom of the oil pan(the big metal thing at the bottom of the motor).
Really, man. . . Open a ******* service manual and read.
And don't feel bad for the crap the other posters have given. If it leaks too much, you just pour oil in and never have to change it because it's always fresh.
Look for the bolt, you can't miss it. Driver's side. The oil filter is right up there as well. Just look up. When changing the filter, just remember to put some oil in the filter and rub some oil on the rubber seal and hand tighten it.
