Sponsored by: CARiD
missfire.
Old May 19, 2009 | 08:39 PM
franksaltz28's Avatar
Default missfire.
Alright this is the second time my car has had a missfire. last time it was only at high rpms and the check engin light wold blink. i changed the spark plugs and wires and it went away. this time it only happens when the car is under a load or at wot. It feels like it could be a real problem because it feels really slow now. I ordered all the parts for a head cam swap and im about to do the swap. Should i locate the problem first or hope that the swap and tune fix it.
Old May 19, 2009 | 09:00 PM
waterbug1999's Avatar
I would do the swap, put new 02's in and get it tuned, and hopefully it goes away.
Old May 19, 2009 | 09:17 PM
LS6427's Avatar
Sounds like you have a plug wire touching a header pipe and its arcing under high power output.
See if thats it first.
Old May 19, 2009 | 10:40 PM
ok ill check that in the morning.
Old May 19, 2009 | 10:55 PM
what did you have the plugs gaped at?
Old May 19, 2009 | 11:01 PM
ItalianoHeck's Avatar
Default Steering
I just Recently got a 98 SS and my steering wheel is so difficult to turn in any direction plus it makes some noise while turning any sugestions?
Old May 19, 2009 | 11:03 PM
yea, maybe start your own thread. But, I would check your power steering fluid level to start..
Old May 19, 2009 | 11:07 PM
LS6427's Avatar
misfire.........steering problem
Old May 19, 2009 | 11:29 PM
they should be gapped at .55
as for the steering problem, make a new thread and someone will get with you.
Old May 20, 2009 | 11:46 PM
problem found. the msd wires were on the headers and were burnt thru. i moved them off and turned them and the car is fine. Is there anything i can put on them to keep them from arching.
Old May 20, 2009 | 11:49 PM
Glad you got it fixed... I dont see how they can touch the headers, they are just long enough to go from the coil to the plug.
Old May 20, 2009 | 11:56 PM
i know they were barely long enough
Old May 21, 2009 | 12:39 AM
LS6427's Avatar
At least you found the issue.
I'd get a new set from Advanced Auto for $36.00. Or take the burnt ones off and wrap them good with electrical tape.
The trick to get them off the headers is to put them on, then twist them at the coils until they are off the headers.
Old May 21, 2009 | 12:42 PM
SStriker's Avatar
I had the same issue with the MSD 8.5 wires...If they are the same ones I got - You can bend those wires at the boot where they go in the plug. Put them on and the bend them away from the headers...It worked for me.
