Sponsored by: CARiD
whining
Old May 24, 2009 | 10:46 AM
ccxxxxxxx's Avatar
Default whining
Ive been getting this whining noise coming from my TA when I turn the steering wheel. It happens everytime and in either direction.
I check the level of the power steering fluid. Before I could though, I first had to clean off alot of gunk from the cap before opening. I noticed pretty much all around the area has this mess.
Anyway the fluid level was low and I put enough to fill to the cold mark since car had not been started all day.
I then to make sure no air was in the sytem started car, turned wheel all the way one way and turned car off. I then did this the other way and so on several times.
I was getting bubbles so air was present. I topped when needed. I then took car for a drive to get up to temp and listen for noise.
The whining is still there but I noticed I only hear it when Im moving and not at all when Im stopped.
any ideas what next?
Old May 24, 2009 | 10:53 AM
ssick1's Avatar
the pump might be going out
Old May 24, 2009 | 11:27 AM
ccxxxxxxx's Avatar
I am now pretty convinced that when the noise Im hearing is coming from the rear end...
What could be causing this.
I found this when I was looking at the rear end...
Old May 24, 2009 | 01:53 PM
ccxxxxxxx's Avatar
edited with pic...
Old May 24, 2009 | 02:23 PM
fccs's Avatar
You say it only happens when you turn.. but you think its the rear now? It most likely is something with the power steering, the rear may just have a leak on the pinion seal, no big deal and prob. isnt related to your power steering issue.
Old May 24, 2009 | 02:33 PM
ccxxxxxxx's Avatar
I really believe its coming from the rear and yes it only happens when turning the wheel and moving. It does not make the noise when I am stopped and turning the wheel.
Old May 25, 2009 | 10:09 AM
ccxxxxxxx's Avatar
bump.
Old May 25, 2009 | 10:42 AM
TAtoad's Avatar
it makes the noise when turning, at low speeds? then yeah it could be your rear
Old May 28, 2009 | 05:47 PM
sscamaro22's Avatar
I have the same exact problem but its deffinitly coming from my power steering. Not to thread jack but I have a slight leak coming from one of the lines. Does anyone know how to tell which is the return line and which is the pressurized one?
