Sponsored by: CARiD
Help quick! Please!
Old Jul 1, 2009 | 10:59 PM
Niko97Rs's Avatar
Default Help quick! Please!
So some electronics were acting funny in my car the other day. I replaced the alternator and cleaned/tightened every ground i could find. Car ran great.
I decided on my way home from work today to give it a little gas to about 4k rpms....
both volt meters immediately dropped to 12 volts on the nose(i have an aftermarket autometer too for piece of mind because of my audio system)
could this be the alternator? maybe it was defective? PLEASE HELP
Old Jul 2, 2009 | 12:12 AM
LS6427's Avatar
Could be a failing alt or a failing battery. Gotta have them checked.
Is your excitor wire ok? They sometimes cause that problem too.
Old Jul 2, 2009 | 08:38 AM
Niko97Rs's Avatar
what exactly is the excitor wire?
Old Jul 2, 2009 | 09:15 AM
PAGregSS's Avatar
Could also be something as simple as the belt is slipping.
Old Jul 2, 2009 | 09:59 AM
Niko97Rs's Avatar
what on earth would cause the belt to slip...?
Old Jul 2, 2009 | 10:25 AM
MjMaro's Avatar
They wear out over time, if you have a good number of miles on your car and haven't changed your belt yet, give it a try, they are cheap and if that's the problem, its a very simple solution. If it's not the problem, you have piece of mind that your belt isn't slipping.
Old Jul 2, 2009 | 02:01 PM
Niko97Rs's Avatar
haha thanks MJ, ill have to look at it in a few as i am stuck at work for 2 more hours
Old Jul 2, 2009 | 05:41 PM
LS6427's Avatar
Its the little tiny red wire that plugs into the top of the alternator. They cause problem before they totally fail.
Old Jul 2, 2009 | 07:01 PM
HTh3r0's Avatar
im guessing belt slip
Old Jul 2, 2009 | 07:15 PM
duh's Avatar
duh
The belt slips because the tensioner spring is broken or starting to break. Then the tensioner needs to be replaced as well....could be a variety of things.....
Old Jul 3, 2009 | 08:01 AM
Niko97Rs's Avatar
you kno...my belt tensioner pulley was making a whirring noise...i didnt even think of that...cuz the alt. is brand new
