Sponsored by: CARiD
Thermostat Change
Old Jul 3, 2009 | 03:58 AM
02_camaroz28's Avatar
Default Thermostat Change
I ordered a 180 degree stat for my 02 Z28. When i go to install this do i just drain the radiator pop off the houseing switch the stat put it houseing back on then fill the radiator back up and im good or is there more to it??? Anything that is vitally important when i install this. Any help or suggestions are appriciated! Thanks!
Old Jul 3, 2009 | 05:07 AM
Kevin01Z28's Avatar
No its pretty simple just drain the radiator and replace. When refilling remove one of the coolant lines from the tb or coolant bypass tube to allow air bubbles to escape. Start it the first time with the radiator cap off and let the thermostat open so you keep an eye on the water level and add if needed.
Since you have an 02 check your owner's manual. Mine said the 5.7L's have a 180 stat factory.
Old Jul 3, 2009 | 12:36 PM
LS6427's Avatar
Just take the two bolts off the t-stat housing, pull it out, swap the t-stats and bolt it back on. Then take the radiator cap off and top off the coolant.
Start the engine, with the radiator cap STILL OFF. While you're waiting the approximate 15 minutes for it to get hot enough for the t-stat to open...massage the upper and lower radiator hoses to move the coolant through, that should take care of all the air bubbles. Works every time. You'll see little bubbles coming up in the radiator fill neck.
I did a coolant flush yesterday and when I do I remove my t-stat and just pull the drain plug and let it run like that for 15 minutes. It flushes every drop out that way. Then I put the t-stat back in and do what I said above.
Just make sure you're bouncing back and forth watching you temp guage just to make sure its not getting too hot...IF a bubble does cause a problem.
The lower hose will always have coolant in it. But if you feel the top hose has nothing in it, squeeze the lower hose alot more.
Old Jul 3, 2009 | 12:58 PM
therealcreeper's Avatar
yep, those guys got it ^^^^
just a tip, use a screwdriver or something to carefully pry and break the seal between the thermostat "neck" and the radiator hose. then twist it back and forth and pull it out. took me a while just because it was 25 degrees outside and there wasnt much room to wiggle with winter gloves on.
just out of curiousity, why are you replacing it? is yours sticking or is it for "performance?"
Old Jul 3, 2009 | 01:07 PM
LS6427's Avatar
I never take the rubber hose off the t-stat housing neck. I just unbolt the t-stat housing, 2 bolts. Then pull the housing away from the water pump, then take the t-stat out.
Old Jul 3, 2009 | 01:46 PM
Im doing it because i drive 100 miles to the track and im hoping to keep my car a little cooler before i get there. And does anyone know how many gallons of coolant i need?
Old Jul 3, 2009 | 02:29 PM
LS6427's Avatar
How much coolant/water you use depends on where you live.
You'd get better cooling at the track by blasting your heater a couple minutes before you stage. The needle should drop significantly.
Might as well go with a 160 and reprogram the fans.
Old Jul 3, 2009 | 11:46 PM
hmmm maybe i just didn't pay close attention when i did mine. i figured since they gave me a new housing along with the new thermostat it was all kinda one piece. didn't know you could just swap out the thermo itself like on standard small blocks. interesting.
i believe the stock thermostat is like 182 or 187. not gonna see much difference. and i bought 2 jugs of the unmixed dexcool(then you mix it 50/50 with water) and i used about 1 and 1/8 of them. i didn't completely drain mine though, just what was above the thermostat.
Old Jul 4, 2009 | 03:21 PM
LS6427's Avatar
Yes, the t-stats coem out of the housings.
Depending on where you live, cold or warm climates. is what dictates how you mix your coolant. We, down here in Florida use no more then half jug of Dexcool, mainly for lubrication of the system. I know alot of people who use 100% hose water, no coolant. Been doing it for decades, its perfectly fine. But if you're in a place where it gets to freezing temps, you'll need coolant of course. 1 and an 1/8 is fine. Thats less than 50% Dexcool, but thats good. Unless you live in Fargo. lol
Old Jul 4, 2009 | 10:55 PM
woulda been good to know haha. at least now i know for the next time.
Old Jul 5, 2009 | 01:47 AM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
EXACTLY.
