Hissing sound near the backpanel of the block
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
i went today to our local racetrack i didnt race my car or anything but i noticed a hissing sound when i was heading home it started when i stop at a red light and when i got in the gas not too much but regulary i get a hissing sound where the stereo is located at BTW my car is a 02 camaro SS A4 mods:LID,flows,cutoff,hypertech programmer has anyone had this problem or is it a problem u can hear it somewhat in the backpanel of the motor......is it something serious
!!!!....any help will help!!!
thanks in advance
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
thanks in advance
It sounds like maybe you have a cracked line of some sort. Maybe an AC line. It makes sense because when you get on the gas a little it spins the AC compressor making a little more pressure in the lines. Has your AC got a little less cold? Thats about the only thing that I can think of.
i went out today to see whats up and i still get a hisssing and ratteling noise in the same spot i mention earlyer........it not a big deal right...i meean it can get fixed?
maby its your mastercylinder going... do you here the hissing when your at idel with your foot off the break or does it seem like the hissing starts when you put your foot on the break? if not it may be vacume lines... it kinda doesent make senc though vacume will increase as rpm increases... weard.. mastercylinder is the only thing i can think of that no one has already suggested.
wrencher
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Where does this noise sound like it coming from??
Inside the car, or in the trans.
If it only makes a noise in a certain gear that would suggest a possible trans problem.
You need to be extremely descriptive in the symptoms to get any advice worth a crap.
What exactly is it doing & where does the noise emanate from?
okay ones again the noise can be heared where the stereo is located at not a the shift **** or anything like that it comes from inside the air ducts where the stereo is located at now it does a hissing & rattleing sound when it jumps into second gear after that it stops from hissing & rattleing and like i said before this hissing can also be heared from the backwall of the motor when its idle and u floor it but not as much as u can hear it from inside when it kicks into second gear>>
Restricted User
I have the same thing - btw last night my the silver canistor looking part of the A/C (sorry cant remember the name of it right now, i just worked a double) was full of condensation....
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
well best of things today no more hissing or rattling sound can be heared probably the engine was acting up but if happens again ima get it fixed thank for all your guyz help!!!
thanks in advance
thanks in advance
